Old 11-26-2013, 09:46 PM   #1
Jabes1
Jabes1's Avatar
Differences in driveline length between 10&12 bolts?
I'm curious if there is any difference in drive line length between 10 and 12 bolt rearends? I guess what my question really is does my driveline need to be lengthened or shortened if I go from a 12bolt to 10bolt and vise versa...
I'm building my truck to cruise on the interstate, and I've located a rearend that's a 10bolt with 2.73's. I don't want to go through the hassle or expense of setting up a rearend with different gears just to find out its not suited for what I want and then have to redo everything. Swapping rearends is far easier and cost effective than changing gears several times...
Welcome to my build thread:
http://67-72chevytrucks.com/vboard/s...d.php?t=574370
Jabes1 is offline   Reply With Quote
Old 11-26-2013, 10:32 PM   #2
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Re: Differences in driveline length between 10&12 bolts?
I've never needed to modify length, but the u joints are different. You'll need a conversion u joint available from any parts store. It adapts the two different era parts together by having two different sized dimensions.
I'm currently running the opposite combination in my 78 truck. A driveshaft out of an 87 model truck which had a 10 bolt rearend with the 78 model 12 bolt rearend. The conversion u joint makes it all work.
By the way, a non overdrive trans, 2.73 gears and 28 inch tall tires is an outstanding combination for highway cruising. I daily drove that exact combo for a lot of years in my 83 stepside. It made my 40 mile freeway commute a pleasure.
Old 11-27-2013, 03:07 AM   #3
Jabes1
Jabes1's Avatar
Thank you TXFirefighter. Ill have to look into if they make a 1350 to 1330 conversion U-joint. I wonder if the yoke is interchageable from my 12bolt to the 10bolt... I'd like to keep my 1350's.
Old 11-27-2013, 03:11 AM   #4
Jabes1
Jabes1's Avatar
I have a Gear Vendor behind my TH400 with 29.74" tires, so Im not sure if its going to be too high of a gear. In theory, with my Tri-Y's and Tuned Port it shouldn't lug the engine too much and be a nice boost in MPG's.
Old 10-29-2015, 06:39 PM   #5
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
Does anyone know if at a certain year, GM trucks went to either metric u-joints or u-joint bolts and nuts?
66 C20 Service Truck:
Old 10-29-2015, 10:43 PM   #6
ElGracho
Gentleman Jim Driver
ElGracho's Avatar
Originally Posted by Tx Firefighter View Post
I've never needed to modify length, but the u joints are different....
Some 12 bolts have 3r yokes like a 10 bolt. I have one I just swapped into my 85. I think it came from a 1979 or 1980 suburban. 3.40 posi...
I didn't change anything with the driveshaft but I do think it was out of the trans about 1/4" more than it was with the 10 bolt.
Joe
'75 GMC Gentleman Jim
'84 Chev C10 Short Wide - Super duper plain (manual steering, manual brakes, no dome light, no cig lighter)
'85 Chev C10 Short Wide - Super plain Vortec 4.8 4L60E trans
also: '81 K30, '83 C30 Crew Dually, '84 M1028 CUCV, '85 M1009 CUCV, another '85 C10 SWB, '87 C10, '87 R30, 2 '89 R3500 Flatbeds
ElGracho is offline   Reply With Quote
Old 10-31-2015, 12:13 PM   #7
LostMy65
LostMy65's Avatar
I've spent the last few days reading up on driveshafts and u-joints.
My concern was knowing which driveshafts were compatible with C10 trucks. It appears from helpful posts from members here that pretty much any GM model vehicle driveline will work - although it may require a combination u-joint. 1310, 1330, etc.
Now my only question that remains is:
Did GM ever switch to metric u-joints?
I have searched and searched, and as far as I can tell; No they did not.
