Old 11-27-2013, 01:56 AM   #1
70c10stepside
Project: Daily Driver!
Alright I know I am crazy. I traded a perfectly fine 1991 Miata for a 67 c30. That has no floor pans at all, and so many odd ends. But don't even care! I am 17 and time to have fun, right? Plus, it'll look awesome pulling my 70!
One of those that look better from the outside lol I'll take more for you all tomorrow. I got it Friday and have been to busy driving it and finding the small issues. The wanna be tow rig crap will be removed Friday when I go to dads. The back is simply looks, bolted to a flat bed. Looks awesome along with the push thing in the front but is SO heavy. Holy cow! Easily a thousand pounds all and all. It has a 350 in it, with a holley. Muncie sm420 and 14 bolt from 80s with a 3.42. Which make it able to be a daily. Get going on the highway and it sips the gas. When I got it home after driving it 60 miles, getting 13 mpg the entire trip, I adjusted the accelerator pump and put the timing at 12 degrees. Which helped it a ton. This truck I have drove it every bit of 200 miles, hasn't burnt any oil, or anything really. I had to fix the taillights after getting it home, when the were bolting on the flat bed they caught a wire which shorted it blowing fuses as fast as you put them in the box. Had to wire up the heater from complete scratch with a toggle switch. Didn't take to long. And duct tape the floors to make it less freezing lol The spid matches the vin, and says it came with air and heat. The motor still has brackets for ac and something behind dash that could possibly be ac related. But the dash is weird. None of the holes for ac, and all is out of proportion from my 70. Don't know. Crazy people. Gas gauge is completely not wired along with the dash really. So no speedo. I just read tach and carry around a broom stick to check gas level. Two things I am extremely use to doing with my 70 lol I'll update as I go. No real plans really. Just go at it and keep driving it, And make plans on the way.
70c10stepside is offline   Reply With Quote
Old 01-18-2014, 09:03 PM   #2
70c10stepside
Re: Project: Daily Driver!
I have not updated this in awhile.. I've been driving it everyday, its been really good to me.. I still gotta get tires. They are a little dry rotted. Other then that all I've done is change oil, diff fluid and wired up the heater. It hits as soon as you hit the switch, no matter if its 5 degrees or 80 degrees outside. With 0 choke.
Old 01-18-2014, 09:09 PM   #3
gdavis
gdavis's Avatar
I see you pulled the boom off. It looks better that way. good luck
Check out Patches
Cars I owned in the past.
1962 chev II Nova - 1965 Chevelle SS - (2)1966 Chevelle SS 1965 chev C10 57 belair chev
1967 Chevelle SS - 1969 Chevelle SS - 1972 Chevelle SS
1967 Buick electra 225 1995 Harley Davidson bager
What does not kill you will make you stronger
1968 c10 short wheel base stepper
gdavis is offline   Reply With Quote
Old 01-18-2014, 10:00 PM   #4
flashed
I like it better too with the front push bumper off as well as the boom .I wish I had your bed on my 1 ton.
flashed is offline   Reply With Quote
Old 01-18-2014, 10:26 PM   #5
jeffro308
That's going to be a sweet western hauler!
jeffro308 is offline   Reply With Quote
Old 01-20-2014, 07:02 PM   #6
70c10stepside
Old 01-20-2014, 07:20 PM   #7
flashed
I see this truck listed on Craigslist ,are you selling it or keeping it ?
Old 01-27-2014, 06:45 PM   #8
70c10stepside
I've considered selling it.. If someone offered a fair offer I'd let it go. But the more time and money I put in it the more I want to keep it.. We'll see what happens.
Took off the beauty rings and got front tires. Also replaced front brake hoses. Old ones were clogged from falling apart on the inside, I've pretty much been driving with rear brakes only. Gotta get rear tires and alignment, then should be good to go.
Old 01-27-2014, 08:10 PM   #9
flashed
I hope you keep it ,its a good looking truck .
Old 01-27-2014, 11:21 PM   #10
Saclandman
Saclandman's Avatar
Good luck with this cool 30. The flat bed looks bad-ass.
Rich J.
1967 Chevy C20 Longbed Stepside w/283 and 4spdSOLD
2002 Chevy Tahoe 4X4 5.3L SOLD
2015 Chevy Silverado Crew 4X4 5.3L
Saclandman is offline   Reply With Quote
