Old 11-28-2013, 06:38 AM   #1
OARNGESI
OARNGESI's Avatar
does anyone make doors like this for a blazer?
does anyone know a place thats makes doors like these for a 69-72 blazer?
70 SWB STEPSIDE
70 BLAZER
09 challenger
OARNGESI is offline   Reply With Quote
Old 11-28-2013, 01:35 PM   #2
lowrodderchev
lowrodderchev's Avatar
Re: does anyone make doors like this for a blazer?
ive seen them done but they were custom made believe they had a write up in 4 wheel mag
my 57 chevy truck build
http://67-72chevytrucks.com/vboard/s...d.php?t=601554
lowrodderchev is offline   Reply With Quote
Old 11-30-2013, 02:48 PM   #3
robs71k5
K5drive
robs71k5's Avatar
I have a set of doors that someone else started. I just haven't gotten around to completing them
robs71k5 is offline   Reply With Quote
Old 12-01-2013, 03:45 PM   #4
bouncytruck
SKINNY TIRES RULE!
bouncytruck's Avatar
I looked at a blazer for sale in Albany Oregon in the late 80's that had doors like that. I've seen two otehr Blazers for sale that had those same openings. My guess is there was someone making them in the 70's but they did not sell very many.
bouncytruck 1972 K5
The Hauler 1994 K1500 Suburban
The Daily2010 Kia Soul
Wife's Ride2014 Fiat 500L
bouncytruck is offline   Reply With Quote
Old 12-02-2013, 10:38 AM   #5
Chulisohombre
Chulisohombre's Avatar
Only ones I've seen are custom made from stock doors and cut down to where you want the half door to sit. Then use sheet metal across the gap and sand and mud as needed to finish and paint.
Chulisohombre is offline   Reply With Quote
Old 12-02-2013, 09:45 PM   #6
cleszkie
cleszkie's Avatar
Unlike the Ford Bronco tub, the Blazer tub has a lot of movement and flex through the door openning. I imagine that the movement/flex of the Blazer tub quickly destroyed whatever aftermarket Blazer fiberglass doors that were out there. Probably why they stopped making them. Just a guess.
cleszkie is offline   Reply With Quote
Old 12-03-2013, 11:46 AM   #7
jaros44sr
jaros44sr's Avatar
Excellant point!.....ill keep that in mind when i build mine, i forgot about the flex, but i can overcome it
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
AS usual, off topic
They say your mind goes second, can't remember the first
Jim
jaros44sr is offline   Reply With Quote
Old 12-04-2013, 02:24 AM   #8
bouncytruck
SKINNY TIRES RULE!
You're probably right.
bouncytruck 1972 K5
Old 12-06-2013, 08:10 AM   #9
Chulisohombre
If you use stock Doors and cut them down they would be the same as Stock just have the cut in them and finish them. Fiberglass probably would Have issues If flexing the truck A Lot or rubbing against trees Or rocks Four bying.
Old 12-06-2013, 08:06 PM   #10
Pife
If you cut down stock doors I don't think you would be happy with the outcome. You would have to reinforce them with tubing. If you just drive your blazer with out the hard top on it flexes the body.
Pife is offline   Reply With Quote
Old 12-07-2013, 01:20 AM   #11
Chulisohombre
If your rockers and rocker Boxes Are Junk or Rot has taken over in the door area it Would be a bigger Problem. But with stock doors they have internal support braces Already and to close them in after Cutting would be similar To boxing your frame for Less Flex. I've seen it done with not a lot Of problems. But a lot I've seen also Have a cage that keeps body flex to a minimum as well. You could cut down a stock door and add a one inch strut brace Across the opening to help with support and also keep somewhat a safer side impact protection. Or you could Buy a tube bender and make tube doors and skin them to have a solid Look. That way flex Wouldn't be a issue either.
Old 12-12-2013, 12:27 PM   #12
docstheman
docstheman's Avatar
That's the gas monkey garage bronco isn't it? Wish Rawlings would build a Blazer.
~ It's a Learning Process ~
Click Here for my Blazer Build: 1971 Blazer 4x4
Click Here for my Work Truck Build: 1970 C10 LWB
Toys: 1970 C10, 1971 Blazer 4x4, 1976 Corvette Stingray L82, 2011 Cadillac CTS 6 speed, 2008 VTX 1800F
docstheman is offline   Reply With Quote
Old 12-12-2013, 02:50 PM   #13
jaros44sr
jaros44sr's Avatar
Yep, saw it on Mecums too
SAFETY FIRST
AS usual, off topic
Jim
