11-28-2013, 11:50 AM | #1 |
rear frame crossmember
Looks like someone at one time hooked a tow chain to my rear crossmember. It is bent and rivets pulled out on one side. Does anyone have one?
11-28-2013, 08:56 PM | #2 |
The Older Generation
Re: rear frame crossmember
Check the parts forum on here. I'm sure someone on there will be parting out a frame. You can't post a wanted to buy because your name is not blue (Premium Member) but if you see someone that is parting out a truck you can buy that piece from them. LockDoc
11-28-2013, 11:39 PM | #3 |
Check out Ece they have a replacement
1970 GMC 1500 stepside 1972 GMC Jimmy Custom 2004 Chevy Colorado 1989 Swb Silverado 1972 Aj's Stormer |
11-29-2013, 12:40 AM | #4 |
Thanks.. I will try the parts board. What is Ece?
11-29-2013, 01:38 PM | #5 |
you can make your own that is either a scrap piece of c channel or a piece ofsquare tubing/// it is really a non critical piece as far as real structual rigid ity just square it up and tack weld in place measure for square again and then weld solid
11-29-2013, 03:17 PM | #6 |
Sorry it's Early Classic Enterprises
