Old 11-28-2013, 02:00 PM   #1
siggyfreud
siggyfreud's Avatar
Donor trucks for disc brakes - GMC same as Chevy?
Hey all,
From reading many threads I see that for a 66 GMC C20 you can use up to (I think) and 87 Chevy C10 subframe/front suspension/brakes and pretty much bolt it in with a few holes drilled.
My local yards don't have any Chevy C10s in the year range, but they do have a few GMCs. Anyone know if, for example, on an 86 GMC C10 the suspension/brake setup was different than a Chevy, or if it's a straight-forward swap as well?
If it is I'll go grab the parts soon!
Thanks!
siggyfreud is offline   Reply With Quote
Old 11-28-2013, 02:25 PM   #2
63burban
Chevy addict
Re: Donor trucks for disc brakes - GMC same as Chevy?
Same stuff, 70s-80s trucks came off the same assembly lines.
63burban is offline   Reply With Quote
Old 11-28-2013, 05:43 PM   #3
chevyrestoguy
chevyrestoguy's Avatar
Also, if you have a choice between a few trucks, look for the cleanest one that has the 1.25" thick (heavy duty) rotors. If it's a self serve yard, then go find as big a sway as you can find from a 3/4-ton or a 1-ton and swap it out for the puny 1/2-ton one while you're at it. If you're going to buy an entire set-up, then install the best parts you can before you pay for it.
Check out my latest endeavor:
https://roundsixpod.com
My build threads:
'55 Chevy: http://67-72chevytrucks.com/vboard/s...d.php?t=247512
'64 C-20: http://67-72chevytrucks.com/vboard/s...d.php?t=446527
chevyrestoguy is offline   Reply With Quote
Old 11-29-2013, 11:44 AM   #4
siggyfreud
siggyfreud's Avatar
Thanks for the info. Chevyrestoguy, did you mean I should install the best parts I can before I install it? If not, can you explain further what you meant?
