Old 11-28-2013, 09:43 PM   #1
68Stepbed
68Stepbed's Avatar
Same size tires all around?
I was wondering if anyone had pics of lowered trucks with the same size tires on all four corners.
The reason I ask is because I'm wanting to get some new wheels/tires over the winter or in the spring. I'm currently at 4.5/6.75 static drop, I'm gonna run 18x9.5 or 18x10 on all four corners, but with different backspacing front/rear. I've been looking at tire options that still has a decent amount of sidewall so it still looks good in the truck's fenders, but still low enough to clear everywhere. I'm also looking at treadwear ratings around 200. A tire I'm leaning toward is the Falken Azenis RT615K in a 295/40/18 all around. It's 27.2" tall which I'm pretty sure will work good up front but I'm afraid will look too small on the rear.
I'd like to run a staggered tire size, but I can't seem to find the sizes I want in matching treads/brands. I was hoping to run a 28" rear tire and 26.5-27" front tire.
So, who's running 4/6ish drops with same size tires all around?
Matt
68 C10 stepside, LS1/700R4, TCI Engineering suspension system
68Stepbed is offline   Reply With Quote
Old 12-02-2013, 11:56 PM   #2
GAc10boy
GAc10boy's Avatar
Re: Same size tires all around?
Interested in this as well. Bumping this up!
GAc10boy is offline   Reply With Quote
Old 12-03-2013, 12:39 AM   #3
Rod Run
Rod Run's Avatar
If you're going to run the same size tire on two different width wheels, your front tires are going to be taller than the rear. Definitely not the optimum idea.
What type of results are you looking to get out of that set up?
______________________
www.northeastrodrun.com
Rod Run is offline   Reply With Quote
Old 12-03-2013, 09:23 AM   #4
68Stepbed
68Stepbed's Avatar
The wheels will be the same size, just different backspacing. I'm getting more into autocrossing and much less car shows. The 200 TW tire is the minimum for most auto-x sanctions like GoodGuys, ASCS, and SCCA Solo II.
The issue is getting a decent sized tire that looks like it still belongs on a truck. The other option(for now) is going with the Nitto NT555 which is available in 295/45/18(R) and 285/40/18(F). They are a 300TW rated tire, though. Obviously, that's still better than the 420TW rating on my current Hankooks, but not optimal for what I'm wanting.
Matt
Old 12-03-2013, 09:49 AM   #5
CC69Rat
CC69Rat's Avatar
Stock UCA/LCAs ? .. or are you running Aftermarket? It has been a while since Ive talked to you.
Chad
1967 C10 SWB - Project Savannah - 6.0/4L80 *Currently underway*
1968 C10 SWB - TOTY 2018, 50th Anniversary Tribute Project * Sold * Pride and Joy
1986 Silverado Short Fleet - Scarlet *Sold*
1985 Silverado Short Fleet *Sold*
2022 Jeep Gladiator Mojave
2001 Jeep Cherokee XJ 4x4 - Lifted, Built
1992 Jeep Cherokee XJ 4x4 - Lifted
2013 Honda Accord EX-L v6 Coupe 6spd (wife's ride)
CC69Rat is offline   Reply With Quote
Old 12-03-2013, 11:29 AM   #6
Rod Run
Rod Run's Avatar
Oh I'm sorry... When I originally saw 9.5 & 10, I thought you were saying two different sized wheels at the same time. I just don't know how to read
Old 12-03-2013, 01:08 PM   #7
cool68
2WD, especially lowered, trucks look much better with a taller rear tire. Matching tread will not be seen, except by roadkill. Even non-matching brands front to rear OK. When was the last time that you walked through a truck show and bent down to read front/rear tire brands and find that they were different and because of that the truck was not acceptable to you?
cool68 is offline   Reply With Quote
Old 12-03-2013, 01:32 PM   #8
Rod Run
Rod Run's Avatar
Maybe I'm just crazy, but I do it all the time. Mismatched tires drive me crazy. I can overlook a lot of things at a show, but whenever someone doesn't match their tires, I always comment on it to whoever I'm with. It's just one of those "little things make all the difference" types of things
Old 12-03-2013, 02:10 PM   #9
Andy4639
Old member
Andy4639's Avatar
Wink Re: Same size tires all around?
Here is mine and I admit I don't like differant brand tires on a show vehicle. If U spend the money on a vehicle to enter it into a show U should have the money to spend on a full set of tires. Putting a vehicle in a show is all about the look!
If your doing like 68Stepbed then fine buy what U need to be competitive.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 12-03-2013, 02:15 PM   #10
Lees68GMC
Lees68GMC's Avatar
15 X 8 Rallys, 4 inch BS, 5 on 5, 275-60-15 BFGs so I can rotate them. Have 5 lug disc brakes up front 12 bolt 5 lug rear-end.
LOVE your Auto-X photo 68StepBed!!
68 GMC SWB Vortec 5.3
98 Chevy Blazer ZR2
94 Mazda Miata, LS2 6 speed, sold
"No matter what happens, nobody gets out alive"
Lees68GMC is offline   Reply With Quote
Old 12-03-2013, 02:30 PM   #11
CC69Rat
CC69Rat's Avatar
I was asking about the LCAs just because of the backspacing up front to run a wider wheel (assuming you'd want to tuck a majority of it under the wheel wells)
At 6.75" drop in the back are you sure they'd go under your fenders? Narrow axle ?
Chad
Old 12-03-2013, 05:09 PM   #12
68Stepbed
68Stepbed's Avatar
I agree. I'd rather have a larger rear tire, but availability is limited. I may even up settling for a higher TW rated tire if need be. As for noticing, yes, I look all the time. The only time I don't mind it is in drag racing applications, where a stickier rear tire is more important than the front runners.
Thanks, Lee. More pics can be seen here--> http://s221.photobucket.com/user/Sli...?sort=3&page=1
Still on all stock control arms. By all my estimates and figures, an 18x10 with 5.5" bs will fit and clear everywhere just fine up front on stock control arms and stock inner fenders with a 27" tire.
The rears are going to be a tight fit, but I'm pretty sure it's doable with 5" backspacing. A lot of figuring will be happening before any final orders are placed, though. I'm also still considering mini tubbing the inner bedsides. If I end up cutting the bedsides, though, a set of 18x12's will be going on along with a narrowed 9" with full floater axles.
Matt
Old 12-03-2013, 05:42 PM   #13
Lees68GMC
Lees68GMC's Avatar
The Measure Twice, Order once is the smart way to go. Hope this doesn't confuse but mines a leaf spring rear GMC, and we replaced the 68 OEM 6 lug 10 bolt with a 1974 1/2 ton Truck 5 lug 12 bolt. Rear end, Backing plate to backing plate was 2" wider (1" each side) spring perches were exact bolt up. Looking at the wheel wells seemed to be plenty of room outboard but those small inside the bed fender wells used to be too close, New rear end is fine.
I'm eventually going to buy & run some New Coys and will measure a bunch of times, over and over again before I order.
98 Chevy Blazer ZR2
Old 12-03-2013, 07:48 PM   #14
68Stepbed
68Stepbed's Avatar
Well, the fleetsides have more room in the rear fenderwells than the stepsides. I do have the wider 72 rearend also.
Matt
Old 12-03-2013, 08:36 PM   #15
jeh
jeh's Avatar
I'm going to listen in on this also....
Matt, maybe I'll get to check out your truck at next years Charlotte Goodguys
Jason
'70 C-10 short fleet 427BB TH400 (SOLD)
'10 Ford F 350
'13 Ford RAPTOR 6.2
MY BUILD THREAD http://www.67-72chevytrucks.com/vboa...d.php?t=612623
jeh is offline   Reply With Quote
Old 12-03-2013, 11:16 PM   #16
CC69Rat
CC69Rat's Avatar
I have a Wheel rite if you want to borrow it. PM an address and I'll send it to you.
Chad
Old 12-04-2013, 08:29 AM   #17
68Stepbed
68Stepbed's Avatar
Thanks, Chad.
Matt
Old 12-14-2013, 02:58 PM   #18
68Stepbed
68Stepbed's Avatar
OK, here's something I tried this morning when the rain cleared. Since the tires I'm interested in are 27.2" tall, I switched the left front and right rear wheels to try to get an idea of how it will look since my front tires are 27" tall.
I must say I don't really care for it. It really need larger rear tires, so I may have to compromise on either mismatched treads, or different TWR tires.
Here's how the rear wheel looked on the other side.
I also checked clearance and discovered the 5.5" backspace interferes with the stock lower control arms, so it's back to the drawing boards for a new setup.
Matt
Old 12-14-2013, 06:58 PM   #19
CC69Rat
CC69Rat's Avatar
Did you ever get the wheelrite tool?
Truck looks killer regardless of what you do to it. I really like that color.
Chad
Old 12-14-2013, 07:03 PM   #20
jeh
jeh's Avatar
The whole "tire and wheel" thing is very stressful. I'm getting my bed painted now and getting ready to set it on the truck soon so I can start doing some measuring myself. I'm hoping to run a 10" wide rear with a 295 tire!!!!!
Jason
'10 Ford F 350
'13 Ford RAPTOR 6.2
Old 12-14-2013, 09:43 PM   #21
cafetony
with the right back spacing 295 is no problem
this is a 305 and i have a 1/2 of an inch on both sides
cafetony is offline   Reply With Quote
Old 12-15-2013, 08:02 PM   #22
68Stepbed
68Stepbed's Avatar
Yes, Chad. I got it sometime last week. I've just been very busy, and with the crazy weather lately, I haven't had time to start checking things with it. I did the front/rear swap thing yesterday, then had to switch it back and put it back in the garage.
Thanks for the compliment.
Yes, it's stressful. I'm gonna do some measuring with the wheelrite tool to make sure that I can fit a 10" wheel and 295 tire in the rear. It tends to look as if my budget wheel plan isn't going to work out as I was hoping, so I ay start talking to my body man about putting tubs in the bed. Now would be the time for that before paint is applied to your bed.
Yeah, the front is fine, and the rear on a fleetside is fine for that, but the stepsides have less room in the rear.
Matt
Old 12-15-2013, 08:25 PM   #23
CC69Rat
CC69Rat's Avatar
Hey, keep that as long as you need to brother. I just wanted to make sure it got there.
That wire 'bendy' bar is to simulate your tire. Width in MM /25.4 = width in inches. × aspect ratio (ex .40) = sidewall height. X2 + rim dia. = height.
Not assuming you don't know,.. just trying to help. You could use fleet bed wheel tubs inside the bed (wood bed right?)
Chad
Old 12-15-2013, 10:21 PM   #24
jeh
jeh's Avatar
Matt, I'm thinking about stopping the body shop on my step bed and selling it. I've got the fever for a Southern Kentucky Classic fleet side kit.....hopefully tires and wheels will be easier to choose also.
Jason
'10 Ford F 350
'13 Ford RAPTOR 6.2
Old 12-15-2013, 10:41 PM   #25
cafetony
I also used a back spacing gauge to get me back spacing
Stock 12 bolt but with my Baer brake set up it pushed everything out .40 out
On each side.
5.5 on a 10 inch wheel is perfect.
I tried to stuff a 315 under it and it worked but it was to close for me.
My truck is being built for autocross, daily driver and goodguys event and hopefully the power tour this year.
For the front on a bag set up. 8.5 with a 4.75 backspacing will not only tuck inside the wheel well right but it lets you run stock inner fenders. You can't drop it on the floor but that's not my intent. The 265 up front is pushing it.
265/35/20 front 27.3 tall by 10.5 wide tire
305/30/20 rear 27.2 tall by 12.2 wide tire
I would of like to go with a taller tire like 40 or a 45 but no one makes that with the size and type of tires I have.
It's the same tires I run on my srt and it hooks up and still gives a good ride.
