Old 11-29-2013, 12:13 AM   #1
bigpetie
bigpetie's Avatar
78 lowering ???
what r u guys using ??? removing leafs & heat springs ???
bigpetie is offline   Reply With Quote
Old 11-29-2013, 12:29 AM   #2
Rod Run
Rod Run's Avatar
Re: 78 lowering ???
You NEVER want to heat a spring to lower ANY vehicle
______________________
www.northeastrodrun.com
Rod Run is offline   Reply With Quote
Old 11-29-2013, 12:41 AM   #3
baclay9
Re: 78 lowering ???
Lol, how low are you wanting to go?
baclay9 is offline   Reply With Quote
Old 11-29-2013, 10:13 AM   #4
bigpetie
bigpetie's Avatar
Re: 78 lowering ???
mabe 2/4 drop
94 EXTENDED CAB
64 CHEVELLE
Old 11-29-2013, 10:39 AM   #5
baclay9
Re: 78 lowering ???
Cut one full coil on the front springs. That will give you two inches. I'm not exactly sure how to do it but you can move your rear hangers up somehow. Might do a search to figure it out.
Old 11-29-2013, 11:18 AM   #6
bigpetie
bigpetie's Avatar
Re: 78 lowering ???
thanks !
94 EXTENDED CAB
64 CHEVELLE
Old 11-30-2013, 11:49 AM   #7
N2TRUX
Happy to be here
N2TRUX's Avatar
Re: 78 lowering ???
You can start by cutting a coil as mentioned. Cutting with a cut off whrel is a good choice. For the rear you can do a shackle for 2" but you might have to notch the bed brace. You can also remove the rivits from the spring hangers and move them up 1.5" to 2" depending on your spring length. You will need to drill holes and bolt them back in place.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 11-30-2013, 02:20 PM   #8
bigpetie
bigpetie's Avatar
Re: 78 lowering ???
got it !
94 EXTENDED CAB
64 CHEVELLE
