Old 07-14-2003, 11:13 PM   #1
slow69
Need Help Quick
Does anyone know of a year truck that used a 12.75 inch flywheel? I'm looking for a starter that will work with the 153 tooth flywheel.
slow69 is offline   Reply With Quote
Old 07-15-2003, 06:46 AM   #2
JimKshortstep4x4
Smile
Do you have a manual transmission on your truck?
Starters for the 153 tooth flywheel should be plentiful, (bolt pattern is straight across instead of diagonal) as a lot of cars came with them. They will bolt to the block and work if you have an automatic. If you have a stick then I think you will have to change the flywheel.
Good luck!
Jim
