Old 11-29-2013, 07:06 PM   #1
mark454
mark454's Avatar
Camshaft for 454 BBC
I am looking for recommendations for a cam for my 454. Engine is 30 over with flattops, edelbrook Performer RPM intake, headers nothing fancy. I don't want anything to wild but I want some lope to it. Thanks
mark454 is offline   Reply With Quote
Old 11-29-2013, 07:13 PM   #2
cableguy0
Re: Camshaft for 454 BBC
Need more info. What transmission? If auto does it have a stall converter? Are you opposed to getting a stall converter?What rear gears do you have? What rpm range are you looking to be in? Are you looking for torque? Lumpy idle and nothing wild don't really go together. Something like the lunati voodoo 10110702 is probably in the range you should be looking at. It will make really good torque down low but still have good mid range power.
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member.
cableguy0 is offline   Reply With Quote
Old 11-29-2013, 07:39 PM   #3
mark454
mark454's Avatar
Turbo 400 with shift kit stock converter with 3.73 gears.
Old 11-29-2013, 09:11 PM   #4
turp mcspray
turp mcspray's Avatar
Flat tops in a 454 = 8.0 compression at best. A cam with any lope at all, will be a slug, due to no cylinder pressure, as a result of the extremely low compression.
Turp Mcspray
New life for an old 2wd, farm blazer
http://67-72chevytrucks.com/vboard/s...d.php?t=505987
My Blazer build http://67-72chevytrucks.com/vboard/s...d.php?t=342299
turp mcspray is offline   Reply With Quote
Old 11-29-2013, 10:21 PM   #5
meatwagon83
meatwagon83's Avatar
comp he 268 is about as big as i would go, NOT the xe268, it is too wild
"DON'T TOUCH THE TRIM!!"-Early Kyler
meatwagon83 is offline   Reply With Quote
Old 12-01-2013, 12:50 AM   #6
Rnd
I would go over to the Chevelle Forum and look around. There seems to be a few guys over there that know what they're doing...
http://www.chevelles.com/forums/forumdisplay.php?f=13
I'm leaning towards the XE 268H
You can also send your planed build to comp cams (or most any cam manufacturer) and they will recommend a grind for your application...
Good luck...
Rnd is offline   Reply With Quote
Old 12-01-2013, 02:34 PM   #7
meatwagon83
xe 268 needs 9-1 and a stall converter
454 bbc camshaft
