Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 11-30-2013, 06:59 PM   #1
Rannos
Rannos's Avatar
Cheap trans yoke.
Took my truck out for a test ride after installing new exhaust and doing a little tuning. My luck with the cheap trans yoke ran out. Best guess is trans yoke broke and drive shaft caught on the drive shaft loop wedging it's self between the loop and the trans. Trans and convertor are less the 2 months old. Lesson learned.
Rannos is offline   Reply With Quote
Old 11-30-2013, 09:26 PM   #2
slowtruck
Re: Cheap trans yoke.
Sorry to hear that man!
Do you think the trans can be saved with an Ultra bell?
http://www.racewithjw.com/
slowtruck is offline   Reply With Quote
Old 11-30-2013, 09:33 PM   #3
Rannos
Rannos's Avatar
Trans is cracked into the pan rail and cracked right before the tail housing. Not sure if internals are damaged yet. Have another I am dropping off at the trans shop Monday.
Old 12-01-2013, 01:21 AM   #4
BigDan3131
BigDan3131's Avatar
Your just lucky that you had the driveshaft loop, if you hadn't I'm sure we would be reading about you pole vaulting your truck instead.
Custom Painter/Restoration Specialist
1965 GMC 3/4 Ton LB SOLD?
1964 Chevy El Camino in full restoration
1991 Chevy S10 288K+ miles 2nd Owner SOLD
2020 RAM 1500 Warlock
BigDan3131 is offline   Reply With Quote
Old 12-01-2013, 05:40 PM   #5
Rannos
Rannos's Avatar
After this little episode I am a believer in loops. That is for sure.
Old 12-04-2013, 06:34 PM   #6
JJLT1
JJLT1's Avatar
wow glad your ok.
x2 on the loop, I hear about broken cases with solid trans. mounts too?? just wondering?
JJ
71 SWB 360 Th400 4.56
JJLT1 is offline   Reply With Quote
