has anyone used A Dart 427 Small block
I am starting to source parts for a new motor for my truck which is a 4x4 so i want to stay away from a BB
Sooooo I was thinking of going with a Dart small block 427 I have being scrounging around on the forum looking for anyone else who has used this block but cant fine much anyone know of any threads on this motor ? Are they work it or Just do a 383 and be happy with it for a lot less money ? |
Re: has anyone used A Dart 427 Small block
I don't think a small block bored and stroked to that degree is really a "streetable" engine. Not something I would want. Generally when you push too far away from the factory design the reliability severely decreases.
I guess it all depends on how much power you really need/want? 400+ from a 383 is easily achieved in a reliable package, and you can get really good low end in them---which is what you want if you are using a 4x4 as a 4x4.
Shawn 1970 Chevy C-10 SWB, 350, TKO 600 5 speed My build http://67-72chevytrucks.com/vboard/s...d.php?t=559881 |
How about a diesel?
4bt...... |
Are you looking at a Little M block or a built Dart 427? I've seen the Little M blocks come through the shop, they are definitely nice pieces, durability shouldn't be a problem. I would suggest that if you get one, having a good automotive machinist check the block over to make sure the critical specs are where they should be. I agree with Lattimer in terms of a production block, there are definitely limits. The quality aftermarket stuff is way beyond what GM ever dreamed of and while over kill for the street if built with streetablity in mind the Dart block should handle it no problem.
Sean "If your gonna be dumb, you gotta be tough" 1960 Chevy Impala Sedan - my 25 year search is over!! 1969 C-10 longbed - Nice day DD ![]() 1970 Chevy Nova - Street and Strip Project ![]() 2002 Acura MDX my DD 2007 Honda Odssey - My Wife's "Mommy Van" |
I had a friend who had a 454 small block built for a truck. It was a little more on the pro side of pro street, it was built as a truck that could be driven but more with the strip in mind. It was a work of art. There is much more that could be said about it but a work of art sums it up. If a man were to build it smaller say on the size of the 427 it would leave more cylinder room [for later if ever needed] and then also maybe a hyd roller could be used instead of some crazy solid roller like was in my friends truck. He kept it a very short time [we both are/were car dealers] and someone else thought they wanted to play as well. I think with the proper planing and the right build [right CR and cam] you could build a very docile 427 that would [almost] purr and have the torque to climb a hill or flat rock face for that matter. Jim
I have a radical idea!
It would work fine, and be very durable (moreso than any production engine). However, to get the most out of it, you are going to need good heads, cam, intake, carb, etc to go with it. At that point, you will have spent a pile of money for an engine that will exceed the capability of the rest of your drivetrain, if it is all stock. Upgrading the trans, transfer case, and axles are going to also add a great amount of cost to the build.
There's a saying in racing that says "Speed costs money - how fast ya wanna go?" I think this applies here. You can build a 383 for a fairly modest investment that will skull drag any production BBC that ever came in a truck. In fact, a well set up 383 will be more than a stock drivetrain can live behind if the truck is going to see extreme duty.
'67 C-30 Dually Pickup 6.2 Turbo Diesel, NP435 ‘72 C-10 SWB , 350 4bbl, TH350 '69 C-10 SWB , 250 L6, 3 OTT '69 GMC C3500, dump truck, 351 V6, NP435 '84 M1009 CUCV Military Blazer 67 C-30 Turbodiesel build thread http://67-72chevytrucks.com/vboard/s...d.php?t=254096 My trucks http://s226.photobucket.com/albums/d...ediafilter=all Member of the 1-Ton Club! |
Don't need crazy fast but.... Heh heh a little bit would be fun!
Drive line will be nv4500 Tcase 205 or a newer chain drive not sure yet . Finding a Good 4 bolt main block can be quite a challenge where I am. So buying a block anyways .heads will be aluminum that's why I am kinda leaning towards a dart short block. Over kill yes but room to grow. Anyways was just wondering if anyone had any Pros /Cons on the small block 427 Config Thank you for the responses |
4 bolts are over rated. If you really want to do it right you want a 2 bolt 010 block. Take that and convert to 4 bolt splayed caps. This would be over kill. A 2 bolt should hold anything that you throw at it, especially with main studs. If you are worried about block flex block fill can always be installed up to the bottom of the freeze plugs. Should be no heat problems filled that low but rigid up the bottom end.
I am a Cummins guy myself but they are a little heavy for these trucks without some decent mods. I am also going to do the NV4500/205 swap using Dodge parts. If I ever install a 12v then I just drop the adapter plate and reinstall the larger input shaft. Just need to make my trans/transfer case adapter. |
![]() Join Date: Feb 2013
What are you planning on doing with the truck?....
I have some experience with both stock blocks and the dart block. The dart block is better for a guy that wants a "plug and play" application. If you want to go the stock block then the there is some grinding to do to even make the crank spin in the block. A couple nights of grinding and hoping ya did it right and things will work ok. I have a 434 sitting in the corner that has I have no idea how many countless hours of torture on it as it has been a mud race motor in a 46 willys jeep and and a 72 chevy 3/4 4x4 rig. It takes a lot to keep them cool and makes crazy power. Basically at then end of each run you need to run a garden hose over the radiator if ya plan on making a run right away.....dart block and aluminium heads 320cc brodix and I can run to town and get a six pack of beer and not overheat with the same cooling setup. I can send some vids of each if ya like......dart block and aluminium heads are the way to go |
Just a highway truck occasional creepin not pounding it or bogging no towing
yes vids would awesome |
#13 |
#14 | |
#15 |
SOLD -77 CHEYENNE SWB, LS SWAPPED -1976 SILVERADO YUBA GOLD/NEUTRAL (2-TONE) |
#16 | |
My biggest problem is trusting anyone around here to do a good Job on machining and backing their work. |
#17 |
#18 |
ebay
#19 |
It all depends on how many cubic dollars you want to put into it.
"Negative people always seem to have a problem for every solution" |
