TH350 or TH400?
Pulling out PG, is either turbo hydro tranny a direct fit?? Is one better than the other?? Thanks in advance..
Re: TH350 or TH400?
TH400 is built to be more heavy duty. It was made to go behind big blocks. If I remember correctly the chevy bell housing should be the same.
68 C10 lwb, 406 sbc, 700R4 86 K30 srw, 454 bbc, TH400 11 Camaro RS, 217 V6, 6M |
Post Whore
![]() Join Date: Mar 2013
Re: TH350 or TH400?
X2...we have a tubo 400 behind Dad's 496 bigblock in his 3/4 ton and we haul heavy loads all the time and bang shift if or burn rubber with it and that tranny is bullet proof. A th 350 is more for a 350 or smaller small block, there are torque and horse power limits as far as I know that you can find so you can tell. My 2 cents. T.J.
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643 1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056 My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw |
Re: TH350 or TH400?
Very cool, so a th350 is perfect for the 283.. Does anyone know if its the same size as the PG?
60-66 Nut
![]() ![]() Join Date: Mar 2007
Re: TH350 or TH400?
Yes a TH350 would be perfect behind a 283. As for fitment, it will bolt right up to the engine. As for the length, that depends on which TH350 you have. There are 3 different tailshaft lengths....3, 6 & 9". Either way, moving the trans crossmember and having the driveshaft shortened are easy and inexpensive to do.
#6 | |
Re: TH350 or TH400?
60-66 Nut
Re: TH350 or TH400?
I prefer the shorter 3" tail shaft housing, but the 6" isn't too bad. All you need is a stock torque converter. Additionally, if you can find a TH350C, which has the lockup torque converter, that will help your mpg's a little. Of course you will have to wire up the lockup feature.
#8 | |
Re: TH350 or TH400?
Re: TH350 or TH400?
the 400 is obviously beefier but i wouldn't be afraid of the 350 behind a big block
Re: TH350 or TH400?
I'm a manual trans guy myself....but I had a 69 Chevelle SS w/396 BBC and TH400 trans. That trans took a lot of abuse and I never had any issues with it. I'd have no problem running another TH400 in the future. I've never had a TH350, so I can't speak on those.
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual http://67-72chevytrucks.com/vboard/s...d.php?t=519869 1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=619024 1964 Short bed trailer |
Re: TH350 or TH400?
That th350c with the locking converter sounds great. Is it rare? What yrs were they around??
![]() Join Date: Mar 2005
Re: TH350 or TH400?
If you haven't bought a transmission yet, you might even want to consider a 200r4. Plenty strong, and you've got 3 gears plus an overdrive. Enable the lock-up feature, and you've essentially have a 5 speed automatic.
There's nothing wrong with a th350 or a th400, though. Both would be a great choice, but if you've got a 283, I would prefer the th350.
Check out my latest endeavor: https://roundsixpod.com My build threads: '55 Chevy: http://67-72chevytrucks.com/vboard/s...d.php?t=247512 '64 C-20: http://67-72chevytrucks.com/vboard/s...d.php?t=446527 |
#13 |
Watch out for your cornhole !
![]() Join Date: Jun 2003
Re: TH350 or TH400?
Th350s come in 6, 9, and 12 inch tailshaft lengths. There is no 3 inch.
#14 |
Who Me?
Re: TH350 or TH400?
I have had many TH350's and they have all been great!!
![]() 1997 Tahoe LT 4D 2WD (DD) 2001 Blazer 4D 2WD 1961 Apache 10 (sold) 1965 C10 Stepper (sold) |
#15 | |
Re: TH350 or TH400?
#16 |
![]() Join Date: Sep 2006
Re: TH350 or TH400?
isn't gear vendors like over $2000. I will be putting the 700r4 behind my 283. I have a one piece aluminum drive shaft to go behind. I also have a 700r4 behind the BB in my other truck. I had a TH350 in my 4x4. I did replace it with a 700R4 and I think I gained about 4 mpg after that. The tranny had mucho miles on it and was still kicking.
"A man and his truck, what a beautiful thing" 65 Short Fleetside BBC 65 Long Fleetside 283 3 on the tree for now. my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536 |
#17 | |
Re: TH350 or TH400?
