Old 12-02-2013, 11:43 AM   #1
Matthewjb
Restoring Frame 69 C10 Short
I'm getting my frame sandblasted in the next couple weeks and I will be painting myself afterwards. What do yall recommend to get it ready for paint and once its ready is anybody partial to any kind of paint or primer. I definitely want to frame to look good and last.
Matthewjb is offline   Reply With Quote
Old 12-05-2013, 11:24 AM   #2
Matthewjb
Re: Restoring Frame 69 C10 Short
Does that Enamel paint from an Agri Supply or Tractor supply work ok....paint they use for farm equipment. That seems to be pretty thick paint. What are yalls thoughts??
Old 12-05-2013, 12:19 PM   #3
KMC3420
KMC3420's Avatar
Here is a one link in regards to frame paint.
http://67-72chevytrucks.com/vboard/s...d.php?t=420849
Keagan
68 SWB C-10 original 350 A/C 503 Mean Green
KMC3420 is offline   Reply With Quote
Old 12-05-2013, 12:24 PM   #4
KMC3420
KMC3420's Avatar
Here is another link on the blitz black.
http://67-72chevytrucks.com/vboard/s...d.php?t=506527
Keagan
Old 12-05-2013, 12:50 PM   #5
Matthewjb
awesome thanks!
Old 12-05-2013, 12:53 PM   #6
Matthewjb
Does it go directly over the bare metal once its been sandblasted or should I spray a coat or 2 of primer on it?
Old 12-05-2013, 01:41 PM   #7
KMC3420
KMC3420's Avatar
I cant speak of the TSC paints or the Blitz black, but I got Eastwood Extreme Chassis black and used Epoxy primer under it. I sandblasted to bare metal, epoxied, and then the Extreme Chassis Black.
Keagan
Old 12-05-2013, 02:03 PM   #8
JJH Jimmy
JJH Jimmy's Avatar
I used POR 15 and top coated it with Eastwood Extreme Chassis Black and am extremely happy with how it turned out. If i wasn't going to blast it i probably wouldn't have used the POR 15, but with a blasted surface the stuff is as tough as nails. I waited until the POR 15 was just slightly tacky and then top coated it that way i didn't have to use the POR 15 etch primer.
1972 GMC Jimmy 4x4 LS Swap
1985 Chevy K20
1994 GMC Yukon
2021 GMC 2500HD Duramax AT4
My "It's a Jimmy Thing" Build
http://67-72chevytrucks.com/vboard/s...d.php?t=583528
Budget Build 1985 K20
http://67-72chevytrucks.com/vboard/s...d.php?t=801565
JJH Jimmy is offline   Reply With Quote
