regearing
Hey folks, Im a new member but long time truck lover. I just recently bought a 1972 K20 Cheyenne super with a 4 speed manual and 4:10 rear. I would like to change the rear gears to a more highway friendly set. Does anyone have a suggestion as to what gearing I should go with? ie 3:73 or 3:03 Any help would be greatly appreciated.
Re: regearing
A K20 would have came from the factory with a Eaton rear axle. 4.11:1 or 4.57:1 only
You will not find any aftermarket gears available. A 14 bolt rear axle from a later model would be a popualr choice. If it were me, I'd look into a overdrive transmission (4L60) solution.
My Classics: '72 K20 Suburban + '65 Dodge Town Wagon '72 Corvette Roadster +'67 Corvette Roadster '73 Z-28 Camaro '63 Ford SWB Uni Pickup '50 Ford Coupe |
#3 | |
Re: regearing
-JASON My grandpa, Gramps, won a 1970 C20 in 1969 for $1. I'm on a mission to restore it before he passes. My 1970 C20 Build Thread |
![]() Join Date: May 2012
Re: regearing
first let me welcome you to the forum, I started out with a I line 292 six and a 4 speed with a 373 rear end, I change to a 276 gears and made a big difference on highway speed, but I think a 308 might have been a little better for all around driving, I never haul much weight, in you case it depends on the loads you are planning on hauling and what you plan to do with your truck.
Re: regearing
At some point mine was swapped to the 14 bolt as bigdav suggested. Its got the 3.73's in it with a BBC/th400 and they are a good highway gear for it. Without a tach, I'd say I'm sub 2k RPM's cruising the highway at 70 with roughly 33-35" tires. That is what I'd recommend doing as long as your not planning any heavy hauling. Mine could use a little more umph when dragging my Toy (about 8,000lbs trailer and all) around on the steep hills but it gets the job done as well as any other truck I've hauled the same load with. I'm looking to switch it back to the 4.11's and then shooting for a winning lotto for a GV overdrive setup. I definitely wouldn't go any lower than 3.73's for a 4x4.
Owner: Times Are Tough Toys 92 4 Runner (Joyce, long story from my time in Africa) Lotsa stuff, just about finished dumping money into it. 89 Mercedes 560 SEL, Merdle. Wrecked 71 Chevy K20, Clifford, BB and 1 Tons |
![]() Join Date: Dec 2012
Re: regearing
Welcome! Couldn't you also do an overdrive trans? Would it be too big a pain in a K?
1970 Longhorn, Front Disc, 350/4 bolt, 882 heads, HEI, Edelbrock, 700R4, HO-52/4.11. 1996 Corvette, Collector Roadster, LT4, 396, 450RWHP, 6sp, 4.11/Dana44/posi 5 point roll bar And let us not grow weary of doing good, for in due season we will reap, if we do not give up. Gal 6:9 Last edited by Longhorn 70; 12-02-2013 at 02:38 PM. |
Re: regearing
Thanks for all 00the responses. I don't plan on hauling any loads over 5000 pounds. I do have a set of 33" tires to try to start with. Id like to keep the manual trans and ill look into a 14 bolt rear. Again thanks for the great ideas. Now i know where to start.
