Old 12-02-2013, 03:05 PM   #1
miniman
Ball joints
Ok, so I got all the whole front end out from the 71 GMC 1/2 ton donor truck for my disk brake conversion. I called Napa to order new ball joints, and they tell me that the 71 with disk brakes are the same as the 68 with drum brakes. Why am I hearing that I have to replace the ball joints if this is the case. Thanks for the help.
miniman is offline   Reply With Quote
Old 12-02-2013, 03:17 PM   #2
leddzepp
Moderator
leddzepp's Avatar
Re: Ball joints
The lower ball joints are the same iirc. The uppers are different for sure.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
leddzepp is offline   Reply With Quote
Old 12-02-2013, 03:26 PM   #3
miniman
Re: Ball joints
Any idea what the differences are? Length, thickness?
Old 12-02-2013, 03:29 PM   #4
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Re: Ball joints
They're both different, upper and lower.
Hit Rockauto, O Reilly, or whatever parts store website you prefer and catalog them.
Uppers are 71-72 specific and then 73-87. Lowers are the same, 71-87.
Old 12-02-2013, 03:30 PM   #5
leddzepp
Moderator
leddzepp's Avatar
Re: Ball joints
Since you have the entire front end out of the 71 you can compare it to your 68 and see what is different.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
Old 12-02-2013, 03:32 PM   #6
Longhorn 70
Longhorn 70's Avatar
Re: Ball joints
If you go to the MOOG suspension parts website, they are different for upper and lower.
1968 C10 Upper
1968 C10 Lower
1971 C10 Upper
1971 C10 Lower
The G series, Vans do share some parts between the years. Some of the differences are taper and bolt diameter.
1970 Longhorn, Front Disc, 350/4 bolt, 882 heads, HEI, Edelbrock, 700R4, HO-52/4.11.
1996 Corvette, Collector Roadster, LT4, 396, 450RWHP, 6sp, 4.11/Dana44/posi 5 point roll bar
And let us not grow weary of doing good, for in due season we will reap, if we do not give up. Gal 6:9
Longhorn 70 is offline   Reply With Quote
