Will a '66 rear end bolt on to '67?
Will a '66 rear end bolt directly into my '67, or would it need to be altered? Both are 1/2 ton (6 lug) with coil springs.
![]() Join Date: Aug 2008
Re: Will a '66 rear end bolt on to '67?
I thought that they were the same measurements up through '69 or '70- but someone with more experience will have to confirm.
18 Till I Die
I put a 65 in my 69... bolts right in. Is a bit narrower tho but still works.
2011 GMC Acadia 1969 GMC BBC LS7 2007 GMC Crew Duramax 1987 Camaro Iroc 350 Tuned Port Injection 42000Km 1987 Chevrolet Silverado 350 TBI 1987 Chevrolet Silverado 350 TBI(yes 2) Take me drunk, I'm too home... ![]() |
You are going to have to measure it for sure. I tried to put a 6 lugger from a slant nose under a 1960 1/2 ton and it did not work at all. The track bar was totally different along with the spring perches for the A arms. They did alot of changes in the 60-66s so you may get lucky. My 1960 was old school all the way down to front motor mounts so you may get lucky.
