Part umbers for upper radiaor hose
Anyone have a Gates, Napa, etc part number for a upper radiator hose.
1971 C-10 350 with A.C. and 4 core radiator. It had one of those mickey mouse chrome bendable pipes with the large chrome ends on it. I'd just as soon have a stock formed hose if I could . Appreciate any help. Dan ![]() |
![]() Join Date: May 2010
Re: Part umbers for upper radiaor hose
Here's a picture showing the reproduction upper hose I bought from Classic Industries for my 69. Hopefully, the picture will be large enough so you can read the number. The bottom line reads "3947120 UT". The numbers appear to be the original GM part #. Top line says "GM AU".
Go into any local autoparts store and ask for a upper radiator hose
Nick Carter 1967 C10 Short bed Fleetside Project Cheap Thrills! 2WD C10 Modern/Performance Alignments Easiest Alignment Ever! |
I'll head down to napa today and see if they can work with that.
My alternator is on the left, not sure how that hose will work. Bbuuuuuut before it's all over with I'll go through Napa's stock or Autozpne geez you'd think I would come across close. When I do I'll put it on here. Thanks for the inputs so far, one of the advantages of going to big shows like the Turkey Day run at Daytona Speedway. Dan |
