![]() Join Date: Mar 2012
separating sm465 from t221 transfer case
im wanting to separate my 465 from the t/case. my book tells me just unbolt and just slide the t/c back. i want to ask here first if indeed thats all it takes? i need to seal up the front and rear adapter. thanx, paul
![]() Join Date: Feb 2007
Re: separating sm465 from t221 transfer case
yup, that's it. now would be a good time to check the wear on the trans/t-case output and input shafts and the coupler.
Steve 1971 GMC Longbox. Full Roller Stroker 489 w/ FiTech EFI, Chris Straub Cam/NV4500/205/D60/14B w. Grizzly Locker and 4.11's. 2" Lift on 33's |
thanx!!
Junk Yartist
There is a cover on the side with 2 bolts. You have to remove that cover to access the 2 adapter bolts INSIDE the adapter. Hey, by the way, I'm a feet dragger.
-Jeremy YOU ONLY FAIL IF YOU STOP TRYING 70 Crew Cab Build Link 70 GMC Suburban 4X4 build thread 95 Yukon Daily Driver Rebuilding an NP205 |
-Jeremy, my book tells me this, thanx....let me know bout them parts lol
snj8198, all looks good!
good to hear! you're on your way.
stay warm out there. it ain't here.
i did find a few places with rebuild kits for this t/c, 1 place 315.00, another 249.00. good grief.
anyone have a spare coupler let me know, everything else looked fine
IIRC, a coupler from a 205 will fit. But if the coupler looks bad, then the input or output shaft is also bad.
But yeah rebuild kits for these are not cheap. It cost me less to swap over to a 205, but i miss my old 221.
1969 K10 - V8, 465, 205, 12 bolt, D44 2002-current 1969 K20 - V8, 465, 221, Eaton, D44 2012-current Nothin' but drums on all 4 corners! past horses in the stable 72 C10-short step (97-02), 68 C10-long fleet (06-12) |
![]() Join Date: May 2003
I have a nice coupler from a NP205 / SM465, but it's a little longer. I believe it's about 4-1/4". It's a GM part I bought from a dealership, but it got very little use. If this will work for you, let me know.
Gary
Gary 72 SWB 4x4 My 72 SWB Build http://67-72chevytrucks.com/vboard/s...d.php?t=259859 |
