cab to axle and frame on an 80 single wheel 1ton
I'm looking for the cab to axle and frame width dimensions on a 80 single wheel 1ton. I'm trying to see if a utility box will swap from a 2000 ford single wheel 1 ton to an 80 chevy
Thanks! |
Re: cab to axle and frame on an 80 single wheel 1ton
not 100% sure, we have a fleet of 8 or 9 super duty's at work ('98-'11) & have mounted & unmounted hitches on them, pretty sure the ford frame is wider.
on my '85 K30, the back of cab to center of wheel is 55", & the frame width is mostly 36" wide. |
Thanks a bunch
I think we need more detail.
If I remember correctly there was a K309 (same as pickup), K310 and K314 model cab chassis, all with different wheelbases. K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
The truck I had the non factory service body on was a standard pick up. As a neat side note the frame from that truck now has a dt466 motor in it with a cab and box off a mid 90s chevy truck per a friend of mine. But I have the all aluminium service body still and have a guy interested in it but he wants to put it on his 2000 ish ford single wheel 1 ton glad cab. My service body is still at my buddy's house and the ford still has the bed on it so I was hoping in all the knowledge here that was some of it. By the way I. Flattered and humbled to have an unsolicited visit from the Keith Seymour
#6 | |
K
| Bookmarks |
