12-03-2013, 11:35 AM | #1 |
Advice for removing the shoulder belt blanking plugs...
I just acquired a pair of '67 shoulder belts - I'd like to remove the plugs that have been there for the last 46 years without damaging them to the point of rendering them unusable - anyone have any suggestions?
Thanks in advance! |
12-03-2013, 12:18 PM | #2 |
Re: Advice for removing the shoulder belt blanking plugs...
They are very brittle, as I'm sure you have guessed. I use a small flat blade screw driver and as gently as possible work around to pry out. I get them at the pick apart and usually 1 out of three break.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner. 1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components. My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703 |
12-03-2013, 12:51 PM | #3 |
i'd spray them good with windex and use a putty knife and hold your breath while prying
12-03-2013, 04:39 PM | #4 |
Do y'all think it would be prudent to warm it up a bit with a hairdryer? I've had success doing that with old/brittle plastic hoses - it tends to make them a bit more pliable....
Also, does anyone have a picture of what they look like from the side? That could help in knowing where to press/pry.... |
12-03-2013, 05:28 PM | #5 |
I wasn't really thinking of saving mine when I removed them so i just popped them right out with a flat blade screwdriver (being careful not to scratch the paint on the roof/c-pillar). They came out easy as could be without breaking or cracking at all.
12-03-2013, 06:03 PM | #6 |
Old member
I'm going to ask a dumb question I guess, why are U wanting to save them if U are putting shoulder belts in the truck. They are small plastic caps that want be worth anything once removed.
Just wondering and I would like to see the orignal shoulder belts please. How did they mount on the floor and retract. I put a set of late model's in my years ago. I don't think I have ever seen a factory set for these trucks.
12-03-2013, 06:19 PM | #7 |
I've only ever seen one set installed in person. I think you pretty much have to "buckle up" twice. If I remember right, the upper part is a buckle and there is a hanger thing to hang it above the door when not in use.
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride American Born, Country by the Grace of God 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! |
12-03-2013, 06:35 PM | #8 |
Here is a pic of only the shoulder belts. The cut off tabs and boots in the middle are spares. No retractors and buckle up twice.
12-03-2013, 06:52 PM | #9 |
Moderator
I have a set of originals in my truck as well. They are a pita to use to say the least!
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man |
12-03-2013, 07:15 PM | #10 |
I have the shoulder belts also, major pain to use so I just use the lap belt.
Picture of plugs.
12-03-2013, 07:25 PM | #11 |
whoa you got 67' shoulder belts! thats a super rare find. lets see some pics
81 camaro 355 4/spd 342 posi my first love. 67 swb step 454/4spd ott 373 posi 4/7 drop. 2000 s10 zr2 little blue truck that never gets stuck. '74 heald super bronc vt8. tecumseh powered moon rover. |
12-03-2013, 08:06 PM | #12 |
Old member
Thanks for posting the pictures. I will stick to my late models after all the comments on them!
12-03-2013, 08:53 PM | #13 | |
12-03-2013, 08:54 PM | #14 |
12-03-2013, 09:26 PM | #15 | |
The Older Generation
I think it would help to heat them up a bit. Couldn't hurt any thing. I try to save that kind of stuff too... LockDoc
12-08-2013, 04:52 PM | #16 |
Well, I wasn't quite successful...I was hoping to find the split shown in some of the pictures Lee H posted and then push on either side while pulling it out, but mine is/was solid. I suppose the good news is that since I didn't mess up the cap I may be able to get creative with some glue and re-use it at some later date if I decide to....
12-08-2013, 05:33 PM | #17 |
I pulled out the old ugly plugs in my cab and bought new ones at the local hardware store, cost 25¢ each. Bought a few more to plug up unused holes in my firewall, they had about ten different sizes.
http://smg.photobucket.com/albums/v655/aaronhero/ |
