Old 12-03-2013, 07:20 PM   #1
HzEmall
HzEmall's Avatar
Pictures Please
Does anyone have pictures of their stock front floor pans in the Blazers or Suburbans? Basically from the firewall to behind the front seats.....no carpet pics would be awesome.
I want to get rid of the gas tank "hump" in my C-10 and I though doing part of a Blazer floor pan would be a easy way to get the process started.
Thanks Guys !
Tim Baillie
Installer/Designer/Fabricator
Trick Factory Customs
Company - www.trickfactory.com
Personal - www.hzemall.com
Instagram - @hzemall
HzEmall is offline   Reply With Quote
Old 12-03-2013, 08:44 PM   #2
gclark1
gclark1's Avatar
Re: Pictures Please
I am not sure if this will help you, but this is what I have from my current build. I can take a few current shots, but the floor is currently covered in Dynamat. Let me know if that would help.
gclark1 is offline   Reply With Quote
Old 12-03-2013, 11:56 PM   #3
HzEmall
HzEmall's Avatar
Re: Pictures Please
Thanks, just wanted to see how flat the front floor is. Looking for a shot straight through the door.
I think it will work well though....
Tim Baillie
Old 12-04-2013, 09:54 AM   #4
tobiahr
tobiahr's Avatar
Re: Pictures Please
heres one i had looking in from the pasenger side behind the passenger front seat. the drivers side is the same. be aware that older model floor pans have less room behind the front seats than the newer models. I think the cutoff for the smaller front floor pans is 73 but i may be mistaken. I can also tell you the surburban floor pan will match your existing seat hardware better than the blazer as the blazers are almost perfectly flat. I have used surburban seats in a truck and vice versa by simply bending the rear mount on the seat to match the different angle, the surburban points down, truck points up. hope this helps
tobiahr is offline   Reply With Quote
Old 12-10-2013, 11:03 PM   #5
motornut
78K & 79C Jimmys
motornut's Avatar
Re: Pictures Please
88 burb drivers side
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
motornut is offline   Reply With Quote
Old 12-10-2013, 11:13 PM   #6
motornut
78K & 79C Jimmys
motornut's Avatar
Re: Pictures Please
79 Jimmy, I think the rear foot area changed after 77
John
