Old 12-03-2013, 08:50 PM   #1
hotrod_991
hotrod_991's Avatar
1.25" VS. 1" brakes
I have a 77 c10 with 1.25" rotors and am looking for a set of drop spindles.
Mt friend has some but they are for 1" rotors. what all would I need to take off his truck to use those spindles on mine? Thank you
"Buckle up I wanna try somethin!!"
"of course it will hold!, I welded it!"
1977 c10 under knife for full rebuild, 5.3l 4l60e drive rain swap, replacement frame and green repaint
hotrod_991 is offline   Reply With Quote
Old 12-04-2013, 12:40 AM   #2
Ziegelsteinfaust
Re: 1.25" VS. 1" brakes
You will need the rotors, calipers, and bearings. Before I decided on my C20 I was thinking of converting a C10 to 4x4.75 to use common car wheels. I think the rotor was from a 1LE Camaro that worked with the standard truck bearings.
Ziegelsteinfaust is offline   Reply With Quote
Old 12-04-2013, 01:07 AM   #3
mgchevyparts
mgchevyparts's Avatar
Why go through all that for less braking? Just buy a set of new drop spindles (1.25" type) and be done with it. Better yet, just cut the coils and don't buy anything.
1957 CHEVY 1/2 TON SHORT BED
1940 FORD 1/2 TON SHORT BED
mgchevyparts is offline   Reply With Quote
Old 12-04-2013, 09:27 AM   #4
hotrod_991
hotrod_991's Avatar
I already have 2" drop coils so no cutty cutty here lol
Old 12-04-2013, 09:28 AM   #5
hotrod_991
hotrod_991's Avatar
so then if i just take his whole loaded spindles I should be fine, including the caliper. it is all still together
Old 12-04-2013, 10:19 AM   #6
Jonboy
Slots go on anything!
Yep.
1974 Jimmy- 5.3/4L80e/NP241
Old 12-04-2013, 10:50 AM   #7
MalibuSSwagon
Is there any real braking difference between the two?
MalibuSSwagon is offline   Reply With Quote
Old 12-04-2013, 11:00 AM   #8
mgchevyparts
Big braking difference once you start to get the brakes (rotors) hot. The much thicker 1.25" will outlast the thinner one and not fade
Old 12-04-2013, 11:09 AM   #9
KQQL IT
At the body shop.
KQQL IT's Avatar
Put 1" rotors on a 1ton swap. Been together for a year.
" That didnt make it any newer "
" Dont antique the equipment "
KQQL IT is offline   Reply With Quote
Old 12-04-2013, 11:09 AM   #10
MalibuSSwagon
Good to know. My next step is upgrade the brakes and add drop spindles.
Old 12-04-2013, 11:37 AM   #11
tony58
Yea, and guys put 13" spokes on duallys, doesn't make it right
A 1 ton with light duty brakes will be fine if you never use it as a 1 ton.
tony58 is offline   Reply With Quote
Old 12-05-2013, 02:23 AM   #12
KQQL IT
At the body shop.
KQQL IT's Avatar
Ha and a 10 bolt. Nope just a pick up truck.
1" rotor is just fine.
Old 12-07-2013, 11:21 AM   #13
hotrod_991
hotrod_991's Avatar
mine is a show truck/weekend toy so wont be used as a truck or abused so I think the 1" should do me just fine
