Old 12-03-2013, 10:36 PM   #1
wayno
Sway Bar & Porterbuilt
I see the porterbuilt forums are down - I know they had a link in there for the installation of the front sway bar but I can't get to it - so hoping someone who has done the install can point me in the right direction. Can anyone take a look at this and tell if I have all the bushings and what not going in the right direction. Additionally, I had it in my head that where it attaches to the frame that one hole would match up and the other would need to be drilled - but appears that one hole (the rear) is where the rivet for the front cross member is - and the front one is right where there's a larger than normal hole in the frame... any help greatly appreciated.
64 Step Side - The Mistress
wayno is offline   Reply With Quote
Old 12-06-2013, 11:24 AM   #2
wayno
Re: Sway Bar & Porterbuilt
giving this a bump - anyone?
Old 12-06-2013, 02:31 PM   #3
ChuckW
ChuckW's Avatar
You'll need to remove that aft rivet on bothe sides for sure. Your link rod looks fine.
I'm not a huge fan of the link rod system, but I know it works. Your install looks correct to me except for the rivet removal.
ChuckW is offline   Reply With Quote
Old 12-06-2013, 07:55 PM   #4
wayno
Thanks Chuck - appreciate the confirmation.
-W
