12-04-2013, 11:42 AM | #1 |
Grounding stock gas tank
I've changed out the fuel gauge and sending unit - both of which were completely dead. Now, the gauge works, but the tank is empty when the gauge reads about 1/4 of a tank! I suspect the tank isn't well grounded. Should there be a ground strap on it somewhere?
Matt Cramer 1972 Chevy C10 - 4.8 swap, long bed, and maybe one dent free body panel somewhere - SOLD 4.8 LS build thread |
12-04-2013, 12:07 PM | #2 |
Msgt USAF Ret
Re: Grounding stock gas tank
Does the gauge read full with the tank full? If so take the wire off the sender unit and ground it to a good ground and see if the gauge reads empty. While the wire is off turn on the key and check the fuel gauge. It should go to way past empty to about the three o'clock position.
If it does then your float arm is out of adjustment or it may be hitting the side of the tank.Or you need to bend it up slightly, . You might want to take the sender out of the tank and ground the flange and with the tan wire on and the key on, move the float arm up and down through it's travel and see if the gauge reads empty and full.
VetteVet metallic green 67 stepside 74 corvette convertible 1965 Harley sportster 1995 Harley wide glide Growing old is hell, but it beats the alternative. |
12-04-2013, 12:29 PM | #3 |
still looking for info on grounding sender - any way to ground the top plate that the sender wire attaches to? or have to rely on tank grounding? where can extra grounding strap be attached to?
12-04-2013, 01:59 PM | #4 |
ground anything to anything is possible if u understand what a ground is
it is not rocket science
12-04-2013, 02:31 PM | #5 |
Msgt USAF Ret
The sender unit should automatically be grounded to the tank when it is installed.
The tank should automatically be grounded to the cab when it is bolted in place. The cab is mounted on rubber supports with bolts in the center but it should be grounded to the engine and the frame with ground straps to ensure good grounding. The engine is grounded to the battery by the negative battery cable mounted on a clean place on the engine. Then the engine should be grounded to the frame with a ground strap to a clean and tight connection There are several other items that require grounding to these major parts, such as the dash cluster to the cab, the wiper motor to the cab and the radio to the cab. As well as all the lights to the frame or radiator support, If you have good clean and tight connections on these grounds your electrical problems will be greatly diminished. As CD says "it ain't rocket science".
12-04-2013, 02:59 PM | #6 | |
All a "ground" is on a 12 volt, negative ground automotive system is a return path to the negative side of the battery. Most if not all systems on a 12 volt auto need 12 volts to work. A "good ground" is simply a connection from your accessory you are trying to supply 12 volts through to the "-" post on your battery. You can measure your ground by putting your digital multimeter (DMM) or volt-ohm meter to the ohms setting, putting one probe on the "-" post of the battery and the other on the spot you are checking, and seeing little or no resistance between your two probes. Little or no resistance = "good ground". Tons or infinite resistance = "bad ground". Good ground = the light, stereo, you name the 12 volt accessory works Bad ground = the accessory doesn't work. To make a bad ground a good ground you need to figure out a clean path back to the battery. In your cab you need to make sure the cab is connected to the frame which has to be connected to the "-" side of the battery. An alternative path would be to connect the cab to the engine which should have a battery cable connected from it to the "-" side of the battery. Like they said, this ain't rocket science. You just need a difference of twelve volts between the + and - side of the accessory you are trying to run which allows the electrons to flow from the + side of the battey through the accessory to the - side of the battery.
'70 cab, '71 chassis, 383, TH350, NP205. '71 Malibu convertible '72 Malibu hard top Center City, MN |
12-05-2013, 11:50 AM | #7 | |
Yes, it does read full when the tank is full. But the thing is so rusty that I have to wonder about the condition of grounds in general. I wasn't sure if the tank had a separate strap to ensure grounding, or not.
12-05-2013, 01:05 PM | #8 | |
Msgt USAF Ret
The stock factory ground had a small cable with a metal clip connected from the cluster to the cab dash. If your gauges work and the dash lights come on then the cluster is grounded.
12-05-2013, 11:01 PM | #9 | |
Sam |
12-06-2013, 02:04 AM | #10 |
Have you been inside the gauge cluster? I noticed when I redid my cluster that I'd bumped the fuel gauge needle and moved it unintentionally. Now my gauge is 1/4 of a tank fuller than the tank is. I'll correct this when I put a tach in, but until then I refill at 1/4 tank.
If I have to be on 4 wheels, It has to be a classic Chevy 1967 c10 Longbed (Hawghauler/Icy weather transport) 2003 BMW K1200GT (Rain bike) 2007 Softail Deuce (Sun bike) 2009 Ultra Classic Electra Glide (Everything else bike) |
04-09-2015, 10:20 PM | #11 | |||
