Is there anyway to keep a wood bed looking good?
I use my 65 as a daily driver so the bed wood spends a lot of time exposed to the elements. I put new wood in about 2 years ago and after the first 6 months it had already started to fade. Now after 2 years of mild use it just looks bad. Anyone have any luck keeping their bed looking good for an extended period?
Thanks |
Re: Is there anyway to keep a wood bed looking good?
what wood and what finish did you use?
ron |
Tear it back apart, sand each board and use an Automotive clear coat ( 6 coats ) hardened and it will look great and be somewhat durable. Only as durable as the clearcoat on your car. I have seen a couple done this way and they look amazing, hold up well with the UV protection and last a lot longer than the Marine varnishes.
I agree with fisher. There is not a woodworking finish that is going to last outside in the elements. They all fail at some point.
Bret
64' Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=586955 |
Moderator
![]() Join Date: Dec 2012
The online tests (Mar K, or GMC Pauls, can't remember which) have shown that wood with clear finish will fail quickly on a bed that is outside. The best finish was wood that was painted with exterior paint. For that reason, I chose to make my boards from synthetic wood. No finish needed, they will last forever.
I take it that you used red oak and it has lost it's red hue. this happens to red oak. most woods do fade. some will actually immediately darken when exposed to light and the best example of that is teak(after being freshly cut) and then over a period of time will eventually go tan.
ron |
Post Whore
![]() Join Date: Mar 2013
63 C-10 uses a Horse stall mat when he hauls stuff in his truck.
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643 1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056 My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw |
I have a cut down sheet of plywood in my bed. I just did the wood last summer so we'll see how it holds up. You could also hit it with a sander in between the strips and put on a couple coats of new clear every spring. When I did mine I was going to cut a slot in the dado that would help with water draining but I got so excited about getting it done I forgot. lol
66 shorty ![]() |
motor oil
Mom, I think I may have broke something. My tires keep spinning and leaving black marks every where ![]() |
![]() Join Date: Aug 2010
Wood moves. Any coating too stiff to move with the wood will fail quickly. When neglected, ALL coatings are doomed to break down under the elements. Some go quickly, while some may last a bit longer.
The smart guy would consider the ease by which he can refresh his finish on a regular basis, avoiding failure altogether, and prolonging it's life indefinitely. Enter boat varnish. After proper initial prep and application, an occasional light sanding and quick refresher coat will keep your deck looking brilliant for as long as you care to maintain it that way. There is no such thing as a once and done clear exterior finish, so you might as well make it easy to maintain. To illustrate, go throw your coffee table into your pool and see how it does. Believe me, the classic boat guys know what's up. Last edited by oem4me; 12-05-2013 at 03:55 AM. |
![]() Join Date: Jun 2006
One option would be to find someone who does Wood Graining, cut pieces of steel to the size and shape of your boards and have them wood grained in the colors you want and clear them.
Custom Painter/Restoration Specialist 1965 GMC 3/4 Ton LB SOLD? 1964 Chevy El Camino in full restoration 1991 Chevy S10 288K+ miles 2nd Owner SOLD 2020 RAM 1500 Warlock |
#13 |
What company made this material? It really looks good!
Keith SOLD - 1963 C10 Short Fleet 350/700R4 4/6 drop 1967 GMC Super Custom - Short Fleet COPO concept w/427 BBC T-400 w/Doug Nash overdrive 4/6 Drop, Buddy Buckets, etc... Frame Off (In Progress) I call it "Vulgar Display of Power" 1980 Silverado Original paint 49k Original miles 4/6 drop Check out my build thread here: http://67-72chevytrucks.com/vboard/s...=1#post6209941 |
#14 |
do what the factory did. southern yellow pine with lampblack and linseed oil
#15 |
Yep, got it at tractor supply for around $50. They are 6' x 4' and 3/4" thick. Carried my big block on its cradle with no issue at all. Didn't slide around and was easy to slide over the rubber to get it to the back of the truck.
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual http://67-72chevytrucks.com/vboard/s...d.php?t=519869 1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=619024 1964 Short bed trailer |
#16 |
#17 |
#18 |
Mar-K has a study they have been doing for 6+ years. The results were that painting the pine black was the only way for the finish to hold up. All clear coats went bad in 2 years. If you want it to live, paint it black.....Kieth
If you want it pretty, keep it covered up and do not use your truck..... ![]() |
#19 |
Several other options here: http://67-72chevytrucks.com/vboard/s...d.php?t=402718
I took mine apart after it faded out, started to cup rtc. And individually linex'ed ( 2 part spray on plastic bedliner) each board, and reassembled with the stainless strips and bolts. You can see the wood grain through most of it as the weather had really gotten to the boards before I sprayed them. The product can be dyed before sprayed or top coat painted just after sprayed for a long lasting color option. |
#20 |
#21 |
#22 |
Moderator
It's TREX facia board material, not deck material. It comes in 10' lengths needed to do a long bed, and in the exact thickness (and widths) as the original boards. I did all the cuts on a radial arm saw. Boards fell into place when installing like they came from GM.
This won't be the choice for someone that is looking for that clear, glossy grain that cleared oak will give you, but for a truck that will see weather, I think it will pay off. The variation in colour on the boards that you see is water spotting. These boards sat outside, stacked, at my local hardware store for a few years before I made them an offer they couldn't refuse. ![]() |
#23 |
bare pine, fitting before black dye, por15 and then a uv protected black exterior paint.
http://kieth.smugmug.com/Trucks/66-GMC/i-pkrLzpm fitting before final install (has dust on it) http://kieth.smugmug.com/Trucks/66-GMC/i-pkrLzpm in progress.....final assembly: http://kieth.smugmug.com/Trucks/66-GMC/i-tLxvc8z Black and polished SS hardware: http://kieth.smugmug.com/Trucks/66-GMC/i-7gSSnFJ outside: http://kieth.smugmug.com/Trucks/66-GMC/i-DZW9XDm ps this #2 pine bed only cost $55.00 for the wood, we then cut it down and cut it to Mar-K prints, worked just fine but the por 15 was a little thicker so we had to go back and cut a little more out of each groove so it would have some adjustment room...... |
#24 |
Kieth, did you brush on the paint(s) or spray? Looks nice.
WANTED: * 60-66 Chevy and GMC FACTORY PHOTOGRAPHY (scans) of pickups and carryalls. Custom Camper Club-- Own a 65-66 Custom Camper? Join us at: http://67-72chevytrucks.com/vboard/g...hp?groupid=117 |
#25 |
Thanks,
We brushed it on and sanded between coats. It still looks good but since I use it all the time we installed livestock trailer mats over the floor to keep the floor from getting scratched up..........and I also installed a tonneau cover to keep the weather out. http://kieth.smugmug.com/Trucks/66-GMC/i-vfHng9N |
