12-04-2013, 07:01 PM | #1 |
Paint or powder coat pulleys?
I'm putting the finishing touches on my engine. I've seen some pulleys that were powder coated, but the grooves were coated, too. Will the belts slip or will the powder coating peel as a result of friction caused by the belt?
67 C-10 LWB "Cow-butt-spotted" (neighbor's term) - work in progress. 350/TH400/3.73 67 Chevelle SS Clone 454/TH400/3.73 |
12-04-2013, 07:43 PM | #2 |
Carpe manana
Re: Paint or powder coat pulleys?
As another option look into zinc phosphate coating (Parkerizing)...there may be a plating company in your area that does this and I believe this is how the pulleys left GM
1972 K5 CST Highlander Blazer: http://67-72chevytrucks.com/vboard/s...d.php?t=708547 1972 K20 Cheyenne Super: http://67-72chevytrucks.com/vboard/s...d.php?t=528308 Members met: ORANGBLAZ, 2003 silverado, MikeCofield, BB72CHEVKT, Duncan&Son, Sameyrasmea72, THENEWMEXICAN, HotRod C/10, brianthelion02, Sport/Truck, ryanroo, michael bustamante, Dirt's72, Already Gone, WestButteTruck, 57taskforce, Moreyel, painterljp, AASmedic, SoCoC10, Lumaestas, carbuff382, Chevyland |
12-04-2013, 09:55 PM | #3 |
I've never been that impressed with powder coating. Chips too easy. I would just use a good quality rattle can with high solids. Easy to repair if needed, cheap, and you can do it yourself and get nice results. Of coarse if you have access to some urethane paint that would be even better.
If I have to be on 4 wheels, It has to be a classic Chevy 1967 c10 Longbed (Hawghauler/Icy weather transport) 2003 BMW K1200GT (Rain bike) 2007 Softail Deuce (Sun bike) 2009 Ultra Classic Electra Glide (Everything else bike) |
12-04-2013, 11:04 PM | #4 |
Powder coat! It looks better, lasts longer and will not cause your belts to slip. I have over 15K miles on my truck, all of the pulley's (except idlers with fixed bearings) are powder coated and show no signs of wear. If you attempt to coat the idlers the lubricant in the sealed bearings will bake out before the powder cures.
12-06-2013, 06:58 AM | #5 |
Thanks for the replies. A rattle can is probably in my future (when it gets warm enough)
12-08-2013, 02:08 PM | #6 |
You're about a 2.5!
