Old 12-04-2013, 08:08 PM   #1
DAVERJ
Tilt column swap
I just bought a used tilt for my 72 blazer,got the non-tilt out tonight and it looks the same but different !!does anyone no if there is more to change to make this work? I thought it was a plug and play but i'm thinking i may have the change that inter shaft also ?
DAVERJ is offline   Reply With Quote
Old 12-04-2013, 09:47 PM   #2
jaros44sr
jaros44sr's Avatar
Re: Tilt column swap
S/B a direct bolt in....can you show pics of where its differant
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
AS usual, off topic
They say your mind goes second, can't remember the first
Jim
jaros44sr is offline   Reply With Quote
Old 12-05-2013, 01:14 PM   #3
jasons
not enough hours in the day
jasons's Avatar
It sounds like you may have a van column. It will work with just a little modification. Here is a thread on it, http://67-72chevytrucks.com/vboard/s...d.php?t=147927. I put one in my Blazer and it was not hard to do.
65 K-10 Short Step
68 C-50
70 K-5
85 K-10
& piles of spare parts
jasons is offline   Reply With Quote
Old 12-06-2013, 08:45 PM   #4
DAVERJ
I do think now it may be out of a van!will confirm over the week-end,thanks for all the info!
