12-04-2013, 10:06 PM | #1 |
55-59 brake pedal assembly
Whats a nice brake pedal assembly to use on these trucks?
firewall mounting my booster/master assembly thanks in advance |
12-05-2013, 02:33 PM | #2 |
Re: 55-59 brake pedal assembly
I'm using http://www.classicperform.com/Store2/Brakes/5559FMB.htm. This one speedway just came out with http://www.speedwaymotors.com/Univer...bly,73778.html.
55 2nd series Chevy Pickup 2019 Chevy Equinox(Daily driver) 2011 Chevy Malibu (Wife's car) MSRA Member I went to a bookstore and asked the saleswoman, "Where's the self-help section?" She said if she told me, it would defeat the purpose. -George Carlin |
12-06-2013, 12:11 AM | #3 |
cool, an ogre smiley Ogre's 58 Truk build how to put your truck year and build thread into your signature shop air compressor timer |
12-06-2013, 01:05 AM | #4 |
WOW! Killer!
12-07-2013, 11:02 PM | #5 | |
See these 3 posts from my build thread: http://www.trifive.com/forums/showpo...&postcount=242 http://www.trifive.com/forums/showpo...&postcount=248 http://www.trifive.com/forums/showpo...&postcount=279 Last edited by roger55; 12-07-2013 at 11:12 PM. |
12-10-2013, 01:32 AM | #6 |
Ahh i see, thanks for posting pics ^^
12-10-2013, 02:45 PM | #7 |
it's not that difficult to mount a booster in the stock mc location using the stock arm
i used a hydroboost on truk but the small vac boosters mounts under floor just as easy. this is my bracket, but the easiest one i've seen to date used the stock mc, gutted and the back cut out. then they stuck a rod thru the mc into the booster mounted on the frame more pics in my thread i believe
cool, an ogre smiley Ogre's 58 Truk build how to put your truck year and build thread into your signature shop air compressor timer Last edited by _Ogre; 12-10-2013 at 07:20 PM. |
12-10-2013, 03:40 PM | #8 |
I sawed off the reservoir part of the original master cylinder, and used the original pedal mount. I used a 3/8 plate bent to a 90, used a hole saw, mounted the hydroboost on the plate behind the original master with a little longer rod, and then ran all the hydraulic lines in the frame. works great. just needed a disc sander to clean up the saw cuts and a little black paint.
http://http://67-72chevytrucks.com/v...d.php?t=489721 |
12-10-2013, 07:23 PM | #9 |
coupeguy you maybe the mc mod i was referring to, post up a pic.
your thread link isn't working for me.
12-10-2013, 11:46 PM | #10 |
He has an extra http:// in it
try this one Ogre http://67-72chevytrucks.com/vboard/s...d.php?t=489721 |
12-11-2013, 11:57 PM | #11 |
thanks warrior; not the one i remember but just as simple
the pics are hard to see but when you realize how simple the idea is you get that ''duh'' moment post 59 of coupeguy's build
