12-05-2013, 10:51 AM | #1 |
14 Bolt full floater 3.21 ring and pinion
Anybody know what a new set of 3.21 ratio ring and pinion for a full floater 14 bolt is worth these days? I hear they are very rare to find?
Thanks. |
12-05-2013, 01:17 PM | #2 |
Re: 14 Bolt full floater 3.21 ring and pinion
Brand new set? about 3-400, used 200
If you've got a 4wd and looking to match the gears, the only thing you will find is a Dodge ratio in a dana44. Those are hard to find also. Makes a nice ratio for a diesel though |
12-05-2013, 01:21 PM | #3 |
But do you know where to find a set for the 14 Bolt? 3.21?
12-06-2013, 03:26 PM | #4 |
give randys ring and pinion a shot, seems like a pretty good source, heard the name pop up on multiple occasions.
12-06-2013, 04:58 PM | #5 |
KW,
do you know if its Ok to mix 3.21 in the rear with 3.23 up front? Are they close enough to not cause a problem? Thanks. |
12-06-2013, 05:14 PM | #6 |
That close , no problem. I've built diffs for the toyota crowd that uses a toyota 5.29s in the rear and I the closest I can match with the Dana 44 front is 5.38
12-06-2013, 06:20 PM | #7 |
12-08-2013, 12:34 AM | #8 |
The only thing you'll find new is 3.42. EastCoastGear has OE for $330. Or if you call them they have aftermarket for 2 something.
http://eastcoastgearsupply.com/i-120...n-3-42-oe.html
68' C20. 283CI w/55CC 305HO heads, NP435 Close Ratio, Corp. 14 bolt FF 3.21, 75' front end swap (everything but the X-member). |
