Truck losing power
Drove my 72 GMC 4x4 home from visiting my kids last week and on the way home I went to pass a Prius and almost didn't make it! As I floored the truck it seemed to lose power, like it was running out of gas, I let off the gas and it would gain power. The engine is a rebuilt 350 with a quadrajet and th350.
Any suggestions where to start looking?
http://smg.photobucket.com/albums/v655/aaronhero/ |
![]() Join Date: Dec 2012
Re: Truck losing power
Look at mister fuel filter inside the carb.
Remove the fuel line Remove the fitting the line screws into There is a small spring and the filter in there. You should be able to blow through the small hole in the end of the filter. If not or it's difficult, there's the problem. That's a start. You can also look at the fuel pump.
1970 Longhorn, Front Disc, 350/4 bolt, 882 heads, HEI, Edelbrock, 700R4, HO-52/4.11. 1996 Corvette, Collector Roadster, LT4, 396, 450RWHP, 6sp, 4.11/Dana44/posi 5 point roll bar And let us not grow weary of doing good, for in due season we will reap, if we do not give up. Gal 6:9 |
#3 | |
71 swb 350/4sp manual 5/7 static drop |
#4 | |
Biscuit |
Also check the air filter.
Thanks, Joe.. 1969 C/10, 348 C.I., 3X2 bbl. V8, 2004r , LWB. |
I was kidding about the Prius, that would have been truly humiliating! If that had happened I would have pulled over and pretended I was having a seizure!
Thanks for the suggestions all!
And here I made it a point to count the priuses I passed effortlessly on the way home from work, 9.
#8 | |
![]() And I agree with everyone else.... fuel filter. Also that polymor float can become saturated and swell up, and not working like it should. That is it will keep the needle and seat closed and not allow gas into the carb so then you will think you are running out of gas. Good luck and let us know what you find.
2005 GMC K2500HD D/A 1993 GMC K1500 2011 Subaru Legacy. 2013 Subaru Outback 1970 C-10 2WD, SWB stepside, 292, TH350, PS, more rust than anything. God is my pilot. ![]() |
#9 | |
I don't know if my carb has been rebuilt and has a new float but my fuel filter is clean as is the air filter. I truly don't want to pull the carb, specially since it's only about 10 degrees outside. I will check it out when I go south to see my kids again in a few days, it's a lot warmer where they live! (If I make it!) Thanks again!
