Desperately need ideas for a th400 shifter!
After about a year I finally got my baby driving again! A 1970 c10, I swapped a new engine in after cleaning it up and upgrading it some, a sbc 350 and I swapped in a th400, my dilemma is it was originally a 3 on the tree and I need to make a shifter on a tight budget, I put an th400 column in it but I need custom linkage for it. Right now I'm getting under the truck to shift it.
1970 c10 LWB (BIG BUILD UNDERWAY) SEMA 19? 1969 GMC K2500 V6 Step Side Long Bed 2008 F250 650hp CUMMINS SWAPPED Daily Driver + too much to list LAST DROP GARAGE, LLC. Check the Shop out! http://www.lastdropgarage.com |
Re: Desperately need ideas for a th400 shifter!
The engine
Go with the B&M unimatic shifter. Here is the link on summit, but Im sure if you shop around you can find it even cheaper. Easy install
http://www.summitracing.com/search/b...s?autoview=SKU
71 swb 350/4sp manual 5/7 static drop |
Alright I like that one but im looking for cheaper ones or a homemade one, ill keep that one in mind though
I had an old international truck with a 283 and turbo 400 and used an old pinto or mustang II shifter , there are a couple on ebay for under $75 right now.
You might call around the local salvage yards and just tell them your looking for a truck floor shifter for your 400. Alot of people throw these B&M shifters in their vehicles and they cover many years so i bet you can find one cheap.
Post a WTB add on craigslist in your area to... someone will have one they arent using anymore. You wont need install instructions... Plenty of videos on youtube and I think you can download the install instructions online
![]() Join Date: Dec 2012
You could get one of these LOKAR Kits. I installed one on my 700R4 and it works great. You could also save a few pennies by getting one of these Shift Arms and fab your own rod and ends.
Don't know how they'd work on a K though.
1970 Longhorn, Front Disc, 350/4 bolt, 882 heads, HEI, Edelbrock, 700R4, HO-52/4.11. 1996 Corvette, Collector Roadster, LT4, 396, 450RWHP, 6sp, 4.11/Dana44/posi 5 point roll bar And let us not grow weary of doing good, for in due season we will reap, if we do not give up. Gal 6:9 |
Alright thanks ill keep that in mind, and I've been eying the lockstep kits but they are very pricey...
![]() Join Date: Sep 2010
Contact cash3481 or Teeitup from this board... the I know the 67 Pickups came with the SBC with a 400 turbo and they probably have the factory shift setup for you... I have a 67 with that combo...
Ok cool I need to save some money up first though I have to many projects and a gas hog of a truck
Old member
I used a floor mounted S-10 shifter for my 700-r4.
Cool part is it has a built in anti theft built into it. ![]() ![]() http://67-72chevytrucks.com/vboard/s...d.php?t=560192 ![]() ![]()
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
Cool that's what I was tryin to find at the junkyard today but couldn't find any
#13 |
Old member
I found this one off of craigslist.
#14 |
Cool I have a b&m floor shifter but for a th350 I'm gonna try to modify it again
#15 |
#16 |
Ok thanks
