Old 12-05-2013, 04:55 PM   #1
grandpaw7
grandpaw7's Avatar
Question Just found this out !
Well,after cleaning the frame up on my 65 C10,i found the stamped numbers,they don't match the vin plate on the cab upper door frame,
I have the bonded title in my name,i guess PO didn't know this as well, i was going to restore this,to original,and one day sell it,guess the frame don't make that much difference and have bought a bunch of parts to bring her back ! Keep going ? to much $ to stop now ..
grandpaw7 is offline   Reply With Quote
Old 12-05-2013, 05:08 PM   #2
cg285
Re: Just found this out !
i don't think it matters. you could "remove" the numbers if you want. where i am at if the title is transferred out of state you need a cop or some govt employee to sign a verification sheet and from experience they give a rats ass about the frame numbers. i had one where the year was wrong on the title and i wanted them to verify it with the frame and they (she) said she could care less.
cg285 is offline   Reply With Quote
Old 12-05-2013, 05:14 PM   #3
61K10
61K10's Avatar
does the vin on the cab match the vin on the title? thats all i would care about, but don't loose the vin tag on the cab. a friend lost his building the car, and had to have it verified by the frame # to get a new vin plate.
1961 chevy K10
my build is------------61K10 build
61K10 is offline   Reply With Quote
Old 12-05-2013, 05:14 PM   #4
markeb01
Senior Enthusiast
markeb01's Avatar
I would be concerned enough to want to get it sorted out with the local DMV. I’ve read too many recent stories where a stolen vehicle missing for 20 years has been seized by law enforcement and returned to the original owner. Usually at great expense to the last owner that lost all his investment.
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502
Old 12-05-2013, 05:27 PM   #5
grandpaw7
grandpaw7's Avatar
I went to local DMV office today, they said vin on cab and title must match,i just got the bonded tile,with my name and truck info sent to me from the State ,they said frame didn't really matter just the cab and vin plate. i had seen one site where the person grinded the frame smooth and layed down a like glass paint job..
Old 12-05-2013, 05:43 PM   #6
markeb01
Senior Enthusiast
markeb01's Avatar
Outstanding. Sounds like you're set!
Old 12-06-2013, 07:47 AM   #7
brokenspoke
brokenspoke's Avatar
FYI...In Texas its illegal to remove a VIN number from anything
brokenspoke is offline   Reply With Quote
Old 12-06-2013, 10:13 AM   #8
60-66
60-66's Avatar
Its illegal in just about every state... BUT same year GMCs the ones Ive seen have no VIN in their frames. I agree above with Mark and your DMV, your all set. Clean it off the frame and avoid this confusion.
IS IT an EATON or Chevrolet rear axle https://67-72chevytrucks.com/vboard/...d.php?t=843778
The hubcap thread http://67-72chevytrucks.com/vboard/s...d.php?t=702839
WANTED : 1963-1966 6 Cylinder Fan Shroud
WANTED :1964-1966 PANEL TRUCK
60-66 is offline   Reply With Quote
Old 12-06-2013, 11:21 AM   #9
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
My 65 is on a gmc frame - there is no VIN on my gmc frame.
66 C20 Service Truck:
Old 12-06-2013, 11:26 AM   #10
kieth
kieth's Avatar
I have a 66 gmc, the cab tag and the numbers on the frame do not match, previous (first owner) says it is original.......no monkey business. The DMV here said it was fine, would not allow one digit because it was supposed to be a letter instead of a number........and the number of digits was only 16 instead of 17 (guess that was how they came).......who knows, we have a good title and the truck came from texas with a good texas title so life is good...............
kieth is offline   Reply With Quote
Old 12-06-2013, 11:30 AM   #11
LostMy65
LostMy65's Avatar
Here is a good reference thread:
http://67-72chevytrucks.com/vboard/s...d.php?t=316902
Old 03-14-2014, 09:40 AM   #12
Old Truck Man
Old Truck Man's Avatar
I have 6 GMC trucks and none of them have a Vin Number stamped on the frame. Most GMC trucks from 64 to 66 have different frames than a chev. they almost all have leaf springs on the rear.
Old Truck Man is offline   Reply With Quote
Old 03-14-2014, 10:04 AM   #13
Keith Seymore
Keith Seymore's Avatar
Make sure you are actually looking at the VIN stamping.
There are often alot of other stampings on the frame, including GM part number, date codes and vendor numbers.
A lot of people mistake those for the VIN stamp.
Due to the nature of the assembly process the VIN stamp will be on the top (horizontal) flange of the frame, where it is difficult to see once the truck is assembled. Frame part numbers and vendor date codes are usually on the vertical side of the rail, where they are easy (ie, easier) to see.
K
Chevrolet Flint Assembly
1979-1986
1986 - 2019
Keith Seymore is online now   Reply With Quote
Old 03-14-2014, 10:20 AM   #14
Robert Haas
My frame has a build ID code, not a VIN, as far as I can tell. I rotisserie built this truck. Frame was bare metal. No numbers on top of the rails at all. I am second owner, Original owner is family so I know the history.
Robert Haas is offline   Reply With Quote
Old 03-14-2014, 11:45 AM   #15
61K10
61K10's Avatar
RH--so what yr and make is your truck?
1961 chevy K10
Old 03-14-2014, 11:58 AM   #16
Robert Haas
Originally Posted by 61k10 View Post
rh--so what yr and make is your truck?
65 gmc sfbbwName:  reflection 3 7-10-2008 6-31-31 PM.jpg
Old 03-14-2014, 01:01 PM   #17
Clyde65
1965 Chevy C10, 2005 4.8L/4l60
Clyde65's Avatar
Since you have a bonded title, it doesnt matter on any of it, as long as the VIN on the door opening and the title match. Your bonded title will be a regular title at the end of 3 years anyway.
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 03-14-2014, 01:07 PM   #18
donthekawguy
donthekawguy's Avatar
Here in Idaho if you buy an out of state vehicle they only check the vin on the cab or dash to trandfer it to Idaho. I spent 20+ years buying and restoring old Kawasaki KZ's and the neck vin and motor numbers never matched. They only checked the neck so any of them could have had a stolen motor and no one would ever check.
66 shorty
donthekawguy is offline   Reply With Quote
Old 03-14-2014, 08:55 PM   #19
gimmy 64
here in CALI I have bought and sold a lot of cars and trucks. the DMV people are not going to get off of there chair and check vin. numbers unless it is a SALVAGE TITLE. and then they tell you to have a chp or local cop check it.LOL
gimmy 64 is offline   Reply With Quote
Old 03-14-2014, 09:17 PM   #20
dwcsr
Hollister Road Co.
dwcsr's Avatar
Here's your issue. DMV may or may not care but if your at a show and a DPS trooper leans over the fender and sees the frame number is different than the door you have a problem there on the spot. You will go home without it until its straightened out. They do check vins that regularly at shows both large and small. If they didn't or can't see it for what ever reason you don't have a problem.
dwcsr is offline   Reply With Quote
Old 03-15-2014, 08:55 AM   #21
Clyde65
Clyde65's Avatar
I understand where your coming from, I havent had that experience yet but that's not to say TXDPS dont troll the local cruises.
Since he has a bonded title, it was inspected by some local vehicle theft detective to get the bonded title. I just went through all that with my 69 Aristocrat Lo Liner TT. All you (OP) will need to do is keep that paper with you as you would your registration.
Clyde65
Rebuild of Clyde
support our troops!
