Old 07-15-2003, 05:39 PM   #1
DuckhunterInTN
Towing capacities?
Is there anywhere that lists the towing capacities of the 69-72 era trucks?
I am specifically wanting to know the capacity of a K10, C20, and K20 w/ a 350 and both auto and manual trans. Gear ratio's should be the most common usually found in these trucks....
2004 GMC 2500HD 4x4 Crew Cab Duramax
2000 Chevrolet ext-cab Z71
1995 Chevrolet ext-cab Z71
1984 Chevrolet K10 6.2 4x4
1972 GMC Jimmy 4x4
1967 Chevrolet C50 Dump truck
1957 GMC 1/2 ton stepside (not running)
DuckhunterInTN is offline   Reply With Quote
Old 07-15-2003, 06:05 PM   #2
68 Suburban
68 Suburban's Avatar
Just sitting here contemplating contemplation.
68 Suburban is offline   Reply With Quote
Old 07-15-2003, 07:49 PM   #3
DuckhunterInTN
Sweet! Thanks!
So it looks like the max trailer capacity for any of these trucks is around 7,000lbs if I am reading this correctly. My 2000 K1500 is rated for around 7800lbs....so much for buying an old C20 in order to get a better trailer puller....
1972 GMC Jimmy 4x4
Old 07-15-2003, 08:12 PM   #4
1969 GMC
1969 GMC's Avatar
Interesting...they list the Blazer as "K10" and "C10" and don't list other K models...but there is the note below the chart that they are given in another pamphlet.
1969 GMC K2500
1996 Honda Accord
2007 Kawasaki KLR 650
1969 GMC is offline   Reply With Quote
Old 07-15-2003, 09:01 PM   #5
Huck
Huck's Avatar
With the right rear end, these trucks can haul as much as any new truck. Problem is stopping. The 99 and newer trucks with 4 wheel disc brakes stop much better. Of course that may not be important~~~
Huck is offline   Reply With Quote
