E-brake cables
My '72 was a disassembled basket case when I got it. I've done a frame off rebuild but I'm finding many parts that are missing. My E-brake pedal assembly is intact EXCEPT I have no cable running from the pedal assembly to the cables mounted on the frame. Has anybody got an idea where I can find the pedal cable assembly to connect it all? Thanks
![]() Join Date: Dec 2012
Re: E-brake cables
Most cables I have seen come each individual cable. Subscribing to this one to see if anybody knows where the best place is.
Keagan 68 SWB C-10 original 350 A/C 503 Mean Green |
Re: E-brake cables
I think Rock Auto has those....I think. Anyone else chime in?
Mine are rusted up and stuck! Although I rebuilt my rear drums I didn't solve that problem so I have to take them apart again and either replace the parking brakes or soak them in a break free and um, brake them free. ![]() |
Moderator
![]() Join Date: May 2007
Re: E-brake cables
Any vendor carries them, autozone might even have them. They are all the same from 69-72 (I am talking about the front cable that runs from the pedal to the drivers side frame rail.)
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man |
Re: E-brake cables
The best place is probably the nearest auto parts store.
Re: E-brake cables
In-line tube has quality stuff..
Shawn 68 chevy K/20 05 chevy 3/4 4x4 71 short step-sold ![]() 71 chevy Beauville van My build. http://67-72chevytrucks.com/vboard/s...d.php?t=633039 |
Re: E-brake cables
'68 Panel Project Boogie Chillin' '68 C-10 Ol' Green |
1969 Custom 30 wrecker
I dislike the ones they sell now a days. They have a smooth black casing and they don't lock in place like the originals with the spiral metal casing.
What that means is when you press the pedal down, instead of only the cable moving, the casing wants to pull through the clamp so the brakes don't lock on properly. Look at the back of your brake pedal assembly and there is a clamp that locks the cable in place. That's the area that it just slides around in. I have 2 new cables and I am replacing them with good used ones because of this.
Bob 63 Impala 283/PG/3.36 (under restoration) 66 Impala 327/PG/3.36 66 Chevelle SS 409/M22/3.55 69 Chevelle 307/PG/3.08 (future restoration) 69 C10 short stepside 454/TH350/3.73 69 Custom 30 tow truck 350/4 spd/4.10 (resto done, CRUISIN TIME!) 71 Cheyenne 20 fleetside 350/4 spd/4.10 71 Chevelle 6/PG/3.08 72 Chevelle 454/M21/4.10 |
Re: E-brake cables
You say In-Line tube has them? I've used ILT before and they have solid stuff. If they have the pedal cable, I'm on it!
#10 | |
Re: E-brake cables
Re: E-brake cables
Found them on In Line Tube! They come as OE or SST. Also, it's the correct 'braided' design. Thanks for the ILT tip!
Re: E-brake cables
I bought an AC delco one. I try to buy all AC delco for my truck. Original parts fit perfect
Jeff 1972 Cheyenne Super SWB 350, Auto, Bucket Seats w/Console, Tach, Factory A/C, P/S ,P/B, Tilt 1998 Chevy 1500 Ext Cab 5.7, Pewter w/blue interior |
