Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 12-06-2013, 01:49 AM   #1
68c10owner
68c10owner's Avatar
pump gas 454 combos?
I`m still searching for a 73-75 c-10 to make into a street/strip hot rod but I`m interested in hearing what kind of engine set ups you guys are running to push these heavy trucks to the low 12`s-high 11`s. Not going to cage it so can`t go faster than 11.49 and must run on junk California 91 pump gas. I`m planning to do a flat top 454 with closed chamber ovals. Compression should be around 9.5:1. Heads are at the machine shop now and are 390 casting closed chamber ovals that are listed at 96cc chambers. They are getting 2.19/1.88 valves and just some mild porting. Plan to keep the rpm range at no more than around 6200rpms. So what are you guys running?
Anthony
68c10owner is offline   Reply With Quote
