12-06-2013, 10:07 AM | #1 |
c10 to a k20
Hello forum. I have a question that I am sure you all can help with and I am sure someone has already done. I have a very nice 1968 c10 long bed body that I would like to convert to a kseries truck. I have not had any luck finding a cheap chassis only 68-72 k series 1/2 or 3/4 ton so I have began looking for a square body truck for a donor which is much easier and cheap to locate. I know of a 1978 k20 longbed that the body is junk on but the running gear is good. Has anyone else taken on the challenge of transferring a 68-72 body over onto a mid to late 70's k series truck or taken the diffs and transfer case and placing them under a c series truck chassis? Any help or input of the best way to achieve this would be really helpful.
12-06-2013, 10:09 AM | #2 |
Re: c10 to a k20
check craigslist, i seen some frames and rolling chassis for the hampton roads area,
67-72K frames ect,ect
Mike 72 C-10 Cheyenne off frame resto and Upgraded to 4 wheel disk, Tilt, Dakota Digital Dash / Rear slider. 421 SBC / TH350 3000RPM Stall Progression Ignition /Holley 750 DP/3:73 gear Eaton Limited Slip unit / 2 1/2 exhaust glasspacks |
12-06-2013, 11:42 AM | #3 |
Re: c10 to a k20
Try the 4x4 page there are many people that have done this.
12-06-2013, 12:39 PM | #4 |
Re: c10 to a k20
I know it requires moving the cab mounts on the chassis and it leaves a fairly large gap between the box and cab unless more mods are done to start with.. Seen it a few times on buddy's trucks, but been several years.
Shawn 68 chevy K/20 05 chevy 3/4 4x4 71 short step-sold 71 chevy Beauville van My build. http://67-72chevytrucks.com/vboard/s...d.php?t=633039 |
