![]() Join Date: Mar 2012
opinoin on headlight relay install
Guys i was looking at the headlight relay set up,
who has one and are they good? and do you still have to use your original dimmer switch
Mike 72 C-10 Cheyenne off frame resto and Upgraded to 4 wheel disk, Tilt, Dakota Digital Dash / Rear slider. 421 SBC / TH350 3000RPM Stall Progression Ignition /Holley 750 DP/3:73 gear Eaton Limited Slip unit / 2 1/2 exhaust glasspacks ![]() |
Moderator
![]() Join Date: May 2007
Re: opinoin on headlight relay install
I have one, totally worth it. Yes you use your original dimmer switch.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man |
The Older Generation
I upgraded the Green '67. I got the relays from a newer F-250 over at the salvage yard. It has two relays in a nice holder with a cover over it and a bracket to bolt to the inner fender, Worked like a champ! Best part is the owner gave it to me... (I actually picked up three sets) I spliced them into my original wiring with no problems. Be sure and solder & shrink tube all of the wire splices. Also be sure to clean all of the contacts in the light circuit, including the dimmer switch connector. (it is usually the worst). I also added a ground strap from the engine to the frame and from the frame to the core support. Made all the difference in the world... No reason you can't do it this way if you take your time and do it right. For anyone who doesn't have the time, or doesn't want to take the time, buy the kit.... LockDoc
Leon Locksmith, Specializing In Antique Trucks, Automobiles, & Motorcycles (My Dually Pickup Project Thread) http://67-72chevytrucks.com/vboard/s...d.php?t=829820 - Last edited by LockDoc; 12-06-2013 at 12:00 PM. |
Watch out for your cornhole !
![]() Join Date: Jun 2003
I do the mod on every one of my trucks. It makes a fantastic improvement. Personally, I've never bought a "kit". It's much cheaper and quicker to just grab relays and sockets and do it myself. There's threads on here detailing the whole mod if you prefer to go the do-it-yourself route.
I found a thread I started on this mod about 7 years ago. I used a relay pack out of some little Mopar goofy econobox car. Relays are very generic. Bosch make a majority of them anyway.
http://67-72chevytrucks.com/vboard/s...d.php?t=188478 ![]() ![]()
hey firefighter. Whats the metal plate attached to the radiator that you have those mounted on? I dont have that in my truck.
That's on my 63 truck build. It's a shroud that bolted on next to the six cylinder radiator to close up the opening (smaller radiator than V8 trucks).
Quit if it's not FUN!!!
I'm with you Tx Firefighter, I put mine together for less than $15. I mounted the relays on the right fender lip, near the battery. I left the original wire and sockets in place. I pulled the old plugs off the lights. New 12 ga. wire to H4 bulbs and insulated male plugs into the old OEM plug for dimmer connections.
Quick, easy, and next to disk brakes, the best thing I've done for my DD.
MY MOTTO: Eat it all up, Wear it out, Use the last few drops, Spend all you've got, Late in life, you'll think of the things you didn't do, not the things you did. - Get out and experience life ! . Robbie Robinson a.k.a. TobyArnot (Toe Bee or not toe bee) ![]() |
Here are the wiring diagrams. First is for Chevy and second is for GMC. I think VetteVet did them but I am not sure... LockDoc
