Rubber mats?
Hi,
I still have the rubber floor mat that came with my truck but it's pretty beat up. Is there a replacement that's exact? |
20' Daredevil (Ret)
![]() Join Date: May 2003
Re: Rubber mats?
Bought mine from vendor Wes at Classic Heartbeat. He was out of stock and had it sent to me from Brothers. It looks great & fits great, appeared to be just like OEM as far as I could tell.
Re: Rubber mats?
Good to know about the quality of the Brothers mat as I just received one from UPS yesterday evening. It's so freaking cold here I will probably have to wait till spring to install it!
Larry 1949 Willys CJ2A, Kubota Turbo Diesel engine, Warn Overdrive, 11 inch brakes, 12volt, Warn M8000 Winch "Little Green" 1970 Rustoleum Roller Red C20 Custom Camper 454 TH400 "Big Red" 1971 K20 6.2 Turbo Diesel 4x4 4spd Ranger Overdrive "Pumpkin Wagon" 2005 VW Beetle Diesel 44+ MPG "Silver Bullet" |
Re: Rubber mats?
I bought a replacement mat from Brothers 2 years ago, first mat did not fit at all ? They did replace it ASAP, but the next one has now split down the center of the "low Hump" tunnel . Also the dimmer switch hole was not positioned properly.
71 C-20 07 Magnum RT AWD |
20' Daredevil (Ret)
Re: Rubber mats?
Well, I hope mine holds up better than that. FWIW it's a high hump, and the dimmer switch hole (and everything else) was in exactly the right spot. I got the one with long tails on each side.
![]() Join Date: Dec 2013
Re: Rubber mats?
Rubber mats and carpets ---acc.com ----auto custom carpets
carpets also many trim /badges/ seals ----trimparts.com seals /gaskets/rubber-plastic plugs ---for any make or model these are the guys who make them for all the speed shops and resellers --steelerubber.com-- nobody better /cheaper or has more stock --nobody ! ![]() |
Re: Rubber mats?
Thanks man!
I may get a new rubber mat next summer too. |
