Old 12-06-2013, 01:42 PM   #1
DA68
Crossed over from '67-'72 land and have a question about a manual to auto swap
This Spring I sold my '68 project and within two weeks, stole this great little 65 for $1,800, complete with roof lights and gun rack! It's an older restoration with a few patches, but it had new brakes, tires, a 3:73 posi and rebuilt 400 SBC. Since then, I've bagged the rear, straightened out some wiring issues and just have had fun with it. I need to finish the patina job, disc brake and bag the front, white wall the tires and replace the 3 speed, 'cause I've got some noise coming from it.
Being new to the '60 - '66 world and knowing the manual crossmember is much different than the auto member, my question is can I use/modify a '67 - '72 auto member or is there a better route. Finding the right year auto member, might be tough. Any help is greatly appreciated.
DA68 is offline   Reply With Quote
Old 12-06-2013, 01:47 PM   #2
aerotruk63
Check The Champ, Demonstrator
aerotruk63's Avatar
Re: Crossed over from '67-'72 land and have a question about a manual to auto swap
Not an expert when it comes to your question, but I was talking to a guy with a 63 and he said he took the crossmember out of a 68 and put it in his.
More so, welcome to this series. Why did you change series?
Old 12-06-2013, 02:19 PM   #3
markeb01
Senior Enthusiast
markeb01's Avatar
Welcome to our side!
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502
Old 12-06-2013, 05:10 PM   #4
DA68
I've always liked the '60 - '66 trucks, but was raised with '67 - '72's. I was at a point with my '68, where it still needed a good bit of money and time to complete, so I decided to sell. I wasn't really looking for an earlier truck, but when I went to look at this '65, there was no way I could walk away from it, for what the guy was asking. I also like the fact, that you just don't see as many of the earlier series trucks around and the lines are classic. So that's how I got here.
Old 12-06-2013, 05:18 PM   #5
aerotruk63
aerotruk63's Avatar
According to the engineering books this series had the largest interior. Do you find it different from the 67-72?
Old 12-06-2013, 06:06 PM   #6
C/10 King
C/10 King's Avatar
I go both ways! The 67-72 forum and the 60-66 forum, for clarification purposes.
C/10 Rene
1966 Short Fleet "The Hag"
1967 CST Short Fleet "Dark Poly"
1971 Short Fleet
1970 Jimmy Custom 2 WD "Golden Ticket"
1972 Blazer 2 WD "Retro Blaze"
C/10 King is offline   Reply With Quote
Old 12-06-2013, 08:27 PM   #7
MARTYZ
MARTYZ's Avatar
I used the cross member from a 72 GMC to mount my 700r4 in my 66, no issues
MARTYZ is offline   Reply With Quote
Old 12-06-2013, 10:29 PM   #8
NEWFISHER
NEWFISHER's Avatar
Nice score. I used a CPP universal fit crossmember on the last one I did. Doesn't answer your GM donor question but is a great fit as an option if you don't find one and only $89.
NEWFISHER is offline   Reply With Quote
Old 12-07-2013, 01:59 AM   #9
Chevy Fleetside
Chevy Fleetside's Avatar
The one in my 65 came out of a 68. It was a direct fit.
"A man and his truck, what a beautiful thing"
65 Short Fleetside BBC
65 Long Fleetside 283 3 on the tree for now.
my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536
Chevy Fleetside is offline   Reply With Quote
Old 12-07-2013, 02:15 AM   #10
Captainfab
60-66 Nut
The factory auto trans crossmembers from '63 and up will interchange. The ones from the late '70's and up are a little different, but will work. Your '65 will have a small crossmember for the e-brake linkage and cables. That can still be used with some ingenuity, or you can simply convert to the '66-'72 cable assembly. The '63-'65 auto trans crossmembers had provisions for the e-brake assembly.
Old 12-07-2013, 04:37 AM   #11
DA68
Glad you clarified C/10 King! Thank you all for the info. I do feel like the '65 is wider in the cabin.
Old 12-07-2013, 08:22 AM   #12
bj383ss
bj383ss's Avatar
Plus one on what the Captain said. My truck has a 700R4 and PO used the parking brake crossmember. Only advice is cut the old manual crossmember out before you install the auto as you will not be able to pull the pan off.
Mine was installed this way with no way to drop the pan. I moved the parking brake crossmember back far enough to allow removal of the pan. When I pull the cab off I am going to cut the old manual crossmember out.
Downside I have no parking brake.
Bret
64' Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=586955
bj383ss is offline   Reply With Quote
Old 12-07-2013, 12:30 PM   #13
Chevy Fleetside
Bret
You can upgrade to the 66 style. It is all cable, you just need all the parts.
I cut my parking brake crossmember up and bolted the parts needed to the auto crossmember to get my brake back. I made a longer connecting bar so the cables would reach. It is crude but effectibe. If I am under the truck later this weekend I will take some pictures.
