Old 12-07-2013, 02:32 AM   #1
JAM1777
B&M trick shift atf
Hello, i just installed a new torque converter in my 69 C10 and when i bought the converter it said other things you might need and i saw the trick shift and ordered it also cause it sounded like it was good stuff. Is it a good product? Will it actually improve shifts? Will it hurtmy transmission? Thanks for any feedback.
I have a turbo 350 tranny and 350 small block
JAM1777 is offline   Reply With Quote
Old 12-07-2013, 12:02 PM   #2
HotRod C/10
HotRod C/10's Avatar
Re: B&M trick shift atf
Dex III would be fine....I prefer Shaefers synthetic but usually hard to find. Am soil or royal Purple are also good stuff. The main thing is changing it as scheduled.
SOLD -77 CHEYENNE SWB,
LS SWAPPED
-1976 SILVERADO
YUBA GOLD/NEUTRAL (2-TONE)
HotRod C/10 is offline   Reply With Quote
Old 12-07-2013, 12:13 PM   #3
Molberg
Molberg's Avatar
It's the same as type F (trick shift). Said so in my instructions. Dextron allows too much slippage on shifts. (TH400 install kit)
-Project Nitemare-
http://67-72chevytrucks.com/vboard/s...d.php?t=607359
Molberg is offline   Reply With Quote
Old 12-07-2013, 12:15 PM   #4
70blackfish
the trick is...the money went from your pocket to theres...over priced type F. is all it is...
69 SWB 780hp Hellcat powered, manual 6 speed, currie 9
70blackfish is offline   Reply With Quote
Old 12-07-2013, 12:37 PM   #5
JAM1777
Ok, well its in now so no turning back. But will it do its job? I mean its not bad for the chevy turbo 350 is it? Is it ok to leave in now till i service the tranny again?
Old 12-07-2013, 12:40 PM   #6
Bigdav160
Bigdav160's Avatar
It's fine. It's just not as slippery as Dextron. It's a cheap man's shift kit.
My Classics:
'72 K20 Suburban + '65 Dodge Town Wagon
'72 Corvette Roadster +'67 Corvette Roadster
'73 Z-28 Camaro
'63 Ford SWB Uni Pickup
'50 Ford Coupe
Bigdav160 is offline   Reply With Quote
Old 12-07-2013, 12:49 PM   #7
HotRod C/10
Just add some friction modifier available at NAPA. Good stuff
LS SWAPPED
-1976 SILVERADO
Old 12-07-2013, 01:34 PM   #8
JAM1777
Ok thanks. I actually plan on putting a shift kit in early next year. So you said add friction modifier, is it just one quart im adding? Or is there a certain amount you add? And is it just added to the tranny fluid you already have in tranny? I appreciate all the help, im new to alot of this and learning as i go along.
Old 12-07-2013, 01:47 PM   #9
HotRod C/10
it has the amount listed on the back........its a small10 oz bottle.
LS SWAPPED
-1976 SILVERADO
