Old 12-07-2013, 02:41 PM   #1
fs64
230 swapping in 700r4
Hello,
I am planning on swapping a 700r4 into my 64 with a 230. I have been reading many of the forums covering this swap and hope I understand it as much as I think I do.
I wanted to run my plans past those with experience and see if I am missing anything.
I acquired a 68 c10 crossmember and mount the flexplate and
correct yoke.
should I get a new radiator or is an external cooler enough?
I think I can modify the "linkage" off a 250 with an auto to actuate the TV cable.
I am undecided on how I am going to control the lockup and the brake switch cutout.
In the future if I wanted to swap in a small block would it be a straight swap?
Any advice or recommendations will be greatly appreciated.
Thank you.
fs64 is offline   Reply With Quote
Old 12-07-2013, 07:09 PM   #2
sigshooter
sigshooter's Avatar
Re: 230 swapping in 700r4
I am interested in doing the same, my biggest challenge is the tv cable and linkage
1965 long bed ( grandpas old truck )
1964 long bed BBW Custom Cab
1966 Short stepside
1964 long bed
1965 long bed Custom Cab, factory air, V-8, powerglide
sigshooter is offline   Reply With Quote
Old 12-07-2013, 08:11 PM   #3
TJ's Chevy
TJ's Chevy's Avatar
I am interested in seeing how this turns out.
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643
1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056
My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw
TJ's Chevy is offline   Reply With Quote
Old 12-07-2013, 08:43 PM   #4
gimmy 64
you should go with the 2004r because it has a closer 1st and 2nd gear.. the 700 is a big drop from 1st to 2nd and the 6 will not like it at all. I believe some one on here has done the switch and figured out how to do the tv cable. I think it was the guy that was putting on throttle body injection but he hasn't been on in a while.
gimmy 64 is offline   Reply With Quote
Old 12-07-2013, 11:09 PM   #5
boucher racing
boucher racing's Avatar
I am about to dive into a similar project this winter. I have a turbocharged inline 250, aka JED. I am running a T5 currently and would like to switch up to an auto to have better control with boost and cruise.
From my research I will need a:
- 153 tooth SFI flexplate
- fab a trans crossmember
- shorten driveshaft
- custom 2800 rpm stall w/ lockup
- trans cooler and lines
- 700r4 trans- wired for OD lockup
- TV made EZ by bowtieoverdrives- http://www.bowtieoverdrives.com/cata...php?ITEMID=218
I have located a trans core (91 chevy C1500) for $100. A local trans builder will build it up HD, for $550.
I am confident about the setup, just a little sketchy about the whole TV cable setup. We'll see!
Boucher'
Build Threads: "JED" 66 GMC C1000
http://inliners.org/ubbthreads/ubbth...1857#Post61857
"Cropwell" 66 C10
http://67-72chevytrucks.com/vboard/s...d.php?t=587639
boucher racing is offline   Reply With Quote
Old 12-08-2013, 12:24 AM   #6
NEWFISHER
NEWFISHER's Avatar
I've done the 700r4 swap on my 50 burb behind a 250 and with a 3:73 rear its great. The 250 has some HP upgrades that help and if it was stock I would definately go with 4:10. There are several diagrams online on the correct geometry for the throttle fulcrum and where to mount the ball stud for the tv cable hook up. Its very important to get the tv pressure corect or you will burn up the trans. Check with bowtie overdrives and TCI. After having a few 700r conversions, I like the TCI wire kit that locks up when shifted into 4th gear and uses a vacuum switch to unlock therfore not needing the extrA brake switch As the engine changes vacuum on decel. Its simple and I can now wire it up myself after buying the kit and seeing how they did it through the connector and the pressure switch.
On the burb I run an external dual pass cooler on the frame rail. It works greaT after the trans warms up. The 700s have a thermo protection switch for 4th geAr and won't allow that shift until it reaches the desired temp. Takes about 10 miles and then it shifts into 4th. I could have plumbed in a radiator/trans internal cooler to "warm" the fluid faster but had the stock radiator until last weekend and tossed in an aluminum one with the internal trans cooler. I have 26,000 on this set up since Dec 2012 and tow heavily with it in the summer. Its been a rockstar And my DD up until the 65 I picked up a couple months ago ( 350/700r4)
NEWFISHER is offline   Reply With Quote
Old 12-08-2013, 08:36 AM   #7
fleetsidelarry
Senior Car Nut
fleetsidelarry's Avatar
I've done the linkage modifications mentioned by NEWFISHER and it worked fine but next time I'll use something like this:
http://www.tciauto.com/tc/valve-bodi...t-pressurehtml
Larry
fleetsidelarry is offline   Reply With Quote
Old 12-09-2013, 10:15 AM   #8
kieth
kieth's Avatar
Originally Posted by fs64 View Post
Hello,
correct yoke.
Thank you.
The 700r4 would be great with the 230 but better later with a 350v8. Send me a pm with your email address and the following information:
rear axle ratio
tire diameter (ground to top of rear tire in inches)
current transmission:
your e mail address
I will send you a detailed spreadsheet which shows usable torque to the ground with your current drive train set up including tire diameter and the speeds in 3rd gear and with the new 700r4 in OD . This will make sure you have enough power to cruise down the highway without the truck falling on its face. Kieth
kieth is offline   Reply With Quote
Old 01-19-2014, 04:59 PM   #9
sandiego65
sandiego65's Avatar
Any progress? please post pictures and information if you have any.
sandiego65 is offline   Reply With Quote
