custom? spare mount
saw this on Orlando CL.... pretty weird
Dad always said, "Son, WISH IN ONE HAND, and ......." -------------------------------------- -------------------------------------- Current toy trucks: '71 GMC 1500 SUPER CUSTOM short/step, orig. dk. blue, 350/700r, ps,pb, A/C '72 Blazer 2wd, ochre & white, 454, tremecTKO 500 5spd. ps, pb, A/C, tilt Last 10yrs of hobby vehicles, had a FEW more in the 50yrs. before these: '66 Plymouth Belvedere City of Miami cop car clone. '70 Nova 406"sb, 13.5-1, solid roller, Brodix, p.glide/t.brake, back halved, 9" Ford, spool 4.88, cage,ladder bar/coilover, 10.5 tire....... SOLD!! '67 C10 short/step side mount spare -- SOLD!! '72 Jimmy 2wd, 350/350, ps, pb, fun driver, lots of bondo & a shiny red paint job..... SOLD!! '69 Nova 350, 4spd, A/C, ps, p.b, ...SOLD!! |
Old member
That is a weird setup for sure! I've never seen the spare like that before either.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
![]() Join Date: Oct 2013
Re: custom? spare mount
not pretty but, sure beats crawling under truck to remove spare. plus, with many trailer hitch receivers that bolt to frame they do not leave room for carrying a spare in original location.
![]() Join Date: Apr 2013
I only am aware of one receiver hitches that will prevent a spare tire from mounting behind the rearend. And it is a special one the mimics some aspects of a fifth wheel pivot. And I've only seen one of them. All others should leave ample room for the spare.
And I highly suggest to go to the cable type spare tire lifts. Get rid of that cradle that will ultimately get hung on a curb, a log or even thin air. A little bit of ingenuity to make the cable lift work flawlessly for many years to come. And you only have to get on the ground to get the center piece out of the wheel once it's on the ground.
1972 Chevrolet Cheyenne LB 1/2 ton finished restoration/rebuild 1995 350 throttle body FI, 4L6E (running on modified GM wiring harness) 3.08 posi rearend, factory A/C on 134A, p/s, p/b, late 70's power windows and locks and cruise, speakers in the dash + 6x9's behind the seat, factory tilt, 40 gallon fuel tank in the bed with integrated tool box, air assist bags on the rearend, sway bar up front and much more. 1972 chevrolet SNB finished 2002, 350 TB FI, TH400, factory A/C, p/b, p/s, (FOR SALE) 1969 Chevrolet 1 ton in work, home made PTO dump bed extended frame, 350 CI , 1972 Chevrolet 3/4 ton suburban future project 1972 Chevrolet 3/4 ton p/u maybe a project one day 1966 Toyota Landcruiser my playtoy |
I've seen a couple of trucks and one van done like that, most of them were done on both sides
1967 C10 lwb two tone, 305 & rat fink style floor shifted 700r4, 20" steelies 2004 2500HD utility bed aka Brutus |
Anyone notice the bed is full of used tires? Ironic?
![]() Keith |
#7 | |
a truck with the dual side spares could make for a really short bed truck. move axle, etc forward and make into a wheel stander drag truck.
Didn't I see that truck in "Hatari"?..
Good for Rhino attacks. J.
1972 Custom Deluxe Highlander C20 1971 Javelin SST New Project 1971 Demon 340 1969 SS El Camino 1968 SS RS 396 Camaro 1967 Barracuda Formula S 1965 140/4sp Corvair Monza Convertible Sorry, but I don't do Fords. |
[QUOTE=tlcrz1972;6406773]I only am aware of one receiver hitches that will prevent a spare tire from mounting behind the rearend. And it is a special one the mimics some aspects of a fifth wheel pivot. And I've only seen one of them. All others should leave ample room for the spare.
That was the Pull-Rite. I saw a few of them, but it's been a long time. Not sure if they make them any more.
Gary 1971 Chevrolet C/10 1951 GMC 100 1977 GMC C15 1955 Chevrolet 3100 |
#11 | |
Pull-Rite is correct, novel idea I almost bought to put behind my suburban, but the fuel tank was the first big issue.
They still show them on their web site. [quote=Katrina/10;6407477] Quote:
#12 | |
I'll be under the truck today, I'll get some pictures.
#13 |
I am a Referee of life.
I saw a Furd with one mounted there once.It had a bedside door and looked factory.I think it was a camper model and put there for the old style cab over that hung past the bed.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
#14 | |
#15 |
Here are a few pictures.
If several of you are interested I can make some to sell. I'll have to figure out matl, hardware and time cost. And If you want the lift included I'll have to see what is available, new and used. I designed this set up to work with the crank shaft for the lift is accessible through the passenger side wheel opening. I didn't see a great way to locate it at the rear near the license plate.
#16 |
Although I've only had 2 flat tires my entire time driving (both on Honda Accords) I will not be without a spare and I prefer one easy to get to.
I like this mod! |
#17 |
Unfortunately I have, though it was no big deal to drop the spare and get her back on all four.
#18 |
[quote=tlcrz1972;6407675]Pull-Rite is correct, novel idea I almost bought to put behind my suburban, but the fuel tank was the first big issue.
They still show them on their web site. Really? I did not check to see if they were still in business. The ones I saw had the underbed spares removed, and some even had the tailpipes relocated to allow the hitch to swing. And you could not back up without putting a pin in it!
#19 | |
It's a great idea! Did you make any up for sale? I would be interested in one including the lift. Do you think cranking though a Stepside wheel opening work?
1970 C10 Short Stepper with 71/72 front clip. |
