Old 12-07-2013, 11:35 PM   #1
vht
TCI coil spring type front end
Anybody running 1 of these? I have this set up along with the 4 link going in my 51. Does this set up handle good? Also, I'm planning on a LS engine, with that p/s pump what press reducer do I need? I know you have to reduce pressure to the power rack but I still want a good feel of the road, so what has worked best for those that have used this set up? I got on tci's site and got the alignment specs but couldn't find nothing on this. Thanks to anyone that can give me some advice.
vht is offline   Reply With Quote
Old 12-08-2013, 12:23 AM   #2
mr48chev
mr48chev's Avatar
Re: TCI coil spring type front end
No experience with the TCI setup but they have been popular with street rodders for years.
As far as the power steering goes I'd probably hook it up as is and try it. It will only take a couple of blocks of driving to know if it is going to work as is or if you need to get the pressure reduction valve.
My ongoing truck projects:
Old 12-08-2013, 10:14 AM   #3
72Mountaineer
72Mountaineer's Avatar
Your PS pump and rack have to match pressures, the type of motor doesn't matter.
72Mountaineer is online now   Reply With Quote
Old 12-08-2013, 01:00 PM   #4
Root2812
Root2812's Avatar
VHT,
I'm glad you brought this up. I just picked up a Fatman coil spring IFS and also have an LS engine. I'm not close to hooking up the power steering so I don't have resources on hand but I do remember other on this forum using the mustang II power rack with an LS. If I remember correctly you need the shims or pressure reducers before you even try it. If you run the higher pressure gm ps pump without the pressure reducer you will blow all the seals out of the rack and ruin it right away. Maybe try calling TCI and ask them, I'm sure they have delt with this before.
My 1950 Chevy build
Root2812 is offline   Reply With Quote
Old 12-08-2013, 04:17 PM   #5
vht
I knew you had to have the press reduced before you even start it. Or at least that's what I read somewhere. I've also heard complaints about steering being to easy, or in other words you didn't have no road feel. I thought I might find someone that has been through it and knew how much to reduce it. I also know the motor has nothing to do with it, but the ps pump does. Later model pumps are different press than early.
Old 12-09-2013, 04:16 PM   #6
jimig1
jimig1's Avatar
I have a TCI in my 55 it was pretty easy install they have a new setup that hats are different and are supposed to keep the alignment better. I used this from speedway http://www.speedwaymotors.com/Mustan...-GPM,5852.html to reduce the flow and have not had any problems with steering.
55 2nd series Chevy Pickup
2019 Chevy Equinox(Daily driver)
2011 Chevy Malibu (Wife's car)
MSRA Member
I went to a bookstore and asked the saleswoman, "Where's the self-help section?" She said if she told me, it would defeat the purpose.
-George Carlin
jimig1 is offline   Reply With Quote
