In line filter suggestions?
Well, now that I have been successfully talked into bending my own replacement fuel line, I'd like to put an extra fuel filter under the passenger side where the two hard lines connect by rubber tubing. That seems like a decent place.
Where do I get a good filter? I know the glass ones can be hazardous. Any suggestions with links? |
Re: In line filter suggestions?
I guess my local cenex carries champion inline filters so that's what I use. http://www.champlabs.com/content/fuel-filters
When there are more choices I usually use hastings. http://www.summitracing.com/parts/hht-gf2
Dane 67 Chevy Fleet 250/4 speed 1/2 ton 68 Chevy 250/4 speed 1/2 ton for parts 49 GMC Grain truck 235 1 1/2 ton 76 Chevy 350/4 speed 1/2 ton |
20' Daredevil (Ret)
![]() Join Date: May 2003
I have one under the truck (was plumbed by the PO) and I get my metal-cased filters at my local NAPA store.
Don't have a part number but it looks like this: ![]()
Thanks guys! Those seem like simple solutions! I await my new tools and a little lime to do this.
Many disagree on whether filters go before or after the pump but if I make my own hardline, and this location gives me trouble, I can fix it easily. Change these every 10K miles? |
I have one before the pump under the truck, and one between the pump and the carb. I use clear plastic ones I get from NAPA. If one is good, 2 must be better.
Shawn 1970 Chevy C-10 SWB, 350, TKO 600 5 speed My build http://67-72chevytrucks.com/vboard/s...d.php?t=559881 |
Laattimer, you were one of the first to give me advice on here and for that I hold you in a place of high esteem. However, everything I have read here on the subject of inline filters, leads me to believe that the clear plasic ones are only second to the glass ones in fragility and fire danger. I like the little colored metal ones by Jeggs but having one after the pump, especially if over the exhaust manifold, would expose my truck to a greater fire risk. Thoughts?
I haven't ever heard of the clear plastic ones failing but you never know. I ran one over the exhaust manifold until it plugged with no problems. I suppose not having a filter there at all would be best in terms of fire risk. I carry a fire extinguisher in the truck at all times; you never know.
Cluster King
![]() Join Date: Nov 2012
You can use one before the fuel pump but it will not stop any particles generated by fuel pump wear from entering the carb. You only need one and it should be mounted between the fuel pump and the carb away from heat as much as possible. With your tube bending skills are you also learning to double flare line? if so, I would get a filter that allows a hard connection in line without rubber or clamps.
Contact me on all of your gauge cluster needs. I specialize in restoration, repair and parts sales for 67-72 Chevy and GMC trucks. email me at tbonegarris@yahoo.com I am also a dealer for Counterpart for gauge cluster parts only. Also see my facebook page, CG&C |
#9 | |
![]() I do need to change out the rubber hoses for better stuff because of the ethanol in the gas, but I haven't gotten that far yet. The one under the truck is just hanging in space, so I don't see any issue with plastic there. I like the plastic because I can see how dirty these are. Last one was full of junk after only 1500 miles, which I think is from the fuel line since the tank is new. The glass filters are bad because they can shatter easily, and the gaskets in them don't always seal the best.
20' Daredevil (Ret)
Can't say what's best, but mine has never failed me in 36+ years. I have the filter pictured above mounted under the cab, so it's before the fuel pump. And the Q-jet has a small filter in the fuel inlet.
If your carb has no built-in filter, it might be a good idea to add one after the fuel pump. But as mentioned, it's generally a bad idea to put one above the engine near the carb. How about placing it directly after the fuel pump? It would be a little harder to get to but might be safer.
I bought a Craftsman double flare kit but I won't get it for a month according to the Sears website and even then I probably won't get started until spring.
Here is what I thought about putting into the engine bay, I could do it without using rubber hose (I imagine) now that this flare kit is coming. http://www.jegs.com/p/JEGS-Performan...60701/10002/-1 What do yall think about that just after the fuel pump? Since my carb has it's own filter inside it anyway....should I even bother with an add on after-pump filter? |
#12 | |
Cluster King
The filter you posted from Jeg's is for -AN fittings and will not work with a double flare steel line. These filters take special fittings and are more commonly used with braided fuel line. If your carb has a filter (like a Q-Jet) then it should be plenty. The in carb filters do a great job at filtering which is what they are suppose to do. It does not matter how many filters you have before it, if it fails then you have junk in the carb. The stock GM fuel system is more than capable of filtering and supplying fuel to your engine unless you are running 9 second 1/4 mile times. Then things just need to be bigger.
#13 |
Well good! A case of "overthinking with insufficient knowledge" then. :-)
I have a Monojet is all. I guess I could put in the little in line metal cased filter the guy at the top of the thread suggested, like under the passenger seat where I have that rubber hose section (if I wanted to), and just be done with it. This is very good news! |
#14 |
![]() Join Date: Nov 2013
The last 67 I had, I used a metal 1 under the cab and then I had a glass replaceable cartridge filter about 4" away from the 850 holley. It worked great.
#15 | |
![]() Join Date: Apr 2013
The need for a double flare is only on brake lines. Hope the kit does both single and double for you.
Put a filter under the truck inside the frame rail, before the fuel pump. And gas it and go. And if the carb has a built in filter thats even better. Think about all the fuel injection systems in the newer vehicles. All the filters are before the fuel pump, and nothing before the injectors (as far as I know of anyway) Quote:
1972 Chevrolet Cheyenne LB 1/2 ton finished restoration/rebuild 1995 350 throttle body FI, 4L6E (running on modified GM wiring harness) 3.08 posi rearend, factory A/C on 134A, p/s, p/b, late 70's power windows and locks and cruise, speakers in the dash + 6x9's behind the seat, factory tilt, 40 gallon fuel tank in the bed with integrated tool box, air assist bags on the rearend, sway bar up front and much more. 1972 chevrolet SNB finished 2002, 350 TB FI, TH400, factory A/C, p/b, p/s, (FOR SALE) 1969 Chevrolet 1 ton in work, home made PTO dump bed extended frame, 350 CI , 1972 Chevrolet 3/4 ton suburban future project 1972 Chevrolet 3/4 ton p/u maybe a project one day 1966 Toyota Landcruiser my playtoy |
#16 | |
Cluster King
Also most factory style fuel injection fuel pumps are in the tank and have an external fuel filter somewhere under the car in line so it can be serviced. It is best for a carberated vehicle to have a filter after the pump in case the pump fails, there is a filter to catch the debris from the failed fuel pump. The in carb filter on a Quadrajet is more than sufficient to filter the fuel.
#17 |
Thanks for the pic man....that makes things a lot easier.
Why would GM double flare when not needed? |
#18 |
Watch out for your cornhole !
![]() Join Date: Jun 2003
The purpose of a double flare is to provide a flare surface that is twice as thick and hence less likely to crack.
You're making a flare that's folded down inside itself, effectively making that part doubly thick. It's all about safety. General rule of thumb for all flared hard lines is, tubing 3/8 and less gets double flared regardless of application. Fuel, brake, hydraulic fluid, whatever.
#19 |
Well why didn't you say so? I'm a bit of a safety freak....I'll double flare mine too.
![]() Thanks man. |
#20 |
![]() Join Date: Jul 2012
Subscribed. Going to move my filter in the next couple of months.
#21 |
![]() Ten Ring, I have used the steel ones like Stocker posted for many years and have one on my truck now, i have also used the plastic kind that Lattimer uses and never had an issue. That's not to say that some of the others may be better, i just never used them as my application just hasn't been that fancy. I agree one before the pump and one after is best, cant say i have always done so.
Mike. Swamp Rat build thread : http://67-72chevytrucks.com/vboard/s...d.php?t=595019 72 3/4T 4X4 4" BDS Lift 33" BFG's |
#22 |
I see I am way in the minority, but I would not put one before the pump. Those pumps are not really made to pull through a filter. On my '83 K20 I killed a Delco mechanical pump in about 6 months when I put a filter under the cab. There is a sock on the pickup and if you put one filter between the pump and the carb it should catch anything in the lines.
'83 K20-TPI '73 C10 '79 C10-ex-diesel(SOLD) '07 Tahoe(Son driving) '14 Suburban-DD '71 C10-current project |
#23 |
I've always put an inline filter underneath the cab between the two sections of metal line.
I have never felt that there was an issue doing it this way for the following reasons. 1) The fuel pump is happy to suck fuel out of the tank at the very back of a Suburban and along the frame rail to the engine. This shows me that the pumps are hearty and able to pull fuel happily. 2) The fuel level is above the fuel pump. Gravity is doing most of the work anyway. Once the lines are full, it acts on a siphon principle anyway. Pluck the rubber line off your pump and point it away and it will drain fuel out of the tank all day long.
#24 | |
Body is still ugly but mechanically the truck is new. And thanks for the compliment!!!
#25 | |
2-This is true for an in-cab tank. Suburban and Blazer (and relocated which is a popular thing) are below the pump so gravity is not helping. Do what you want, but my experience with below frame tanks is my experience. And IMHO it is still un-necessary to have 2 filters. You will be better off replacing the sock on the pickup and adding a good filter after the pump and before the carb.
