07-15-2003, 10:01 PM | #1 |
PROJECT 7DEUCE
Help me....
Can someone help me out with my throttle set-up... Went from s.b. to b.b. and with the b.b. in the rear hole the cable appear's to be to short .here is a pic of the 2 cable's I have ... Do I need a b.b. specific cable??
GO BIG GREEN GO DUCKS MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
07-15-2003, 10:02 PM | #2 |
PROJECT 7DEUCE
2nd pic 2wd 72 chevy
07-15-2003, 11:22 PM | #3 |
i can't remember for sure but i think all the two wheel drives were the same and they had a longer one for the 4x4. what thottle cable bracket are you useing on the carb?
mine is hooked up useing the factory peices except i removed the pin and drill a hole to move the cable out a little to keep it lined up with the carb.
69 chevy short wide box project 70 GMC jimmy project |
07-16-2003, 12:14 AM | #4 |
PROJECT 7DEUCE
Thank's phillip just stopped buy and showed me the problem. I need a 4wd one because I set the motor back so far. Thank's for the reply.
07-16-2003, 12:46 AM | #5 |
Yup... The 4wd is a shorter cable and Im looking in my magic box of spare parts for one in the morning...
