12-08-2013, 03:53 PM | #1 |
A question on installing an original '67 shoulder belt
Here's a picture of the bolt - it's 1 1/2" long under the head with a 3/4" long shoulder, 1/2" long thread, and 1/4" long end...when I screw it into the threaded hole it bottoms out when the shoulder reaches the cab, such that the belt swings quite freely - is this normal?
Thanks! |
12-08-2013, 04:39 PM | #2 |
Re: A question on installing an original '67 shoulder belt
I'm not 100% sure about this for the 67-72's, but I know that on the 73-up shoulder belts this is how it's designed, so it should be the same.
Zach 1970 Chevrolet Custom Camper K20 1971 GMC Super K2500, 12V/NV4500 swap in progress 1971 Chevrolet Custom C10 1972 Chevrolet Custom Deluxe C20, 5.3/4L60E 1972 Oldsmobile Cutlass Supreme, 455/TH400, 3.73 posi 2004 GMC Sierra 2500HD, LB7/Allison, CCSB 2005 GMC Sierra 1500, 5.3/4L60E, CCSB |
12-08-2013, 05:52 PM | #3 |
Yes, swivel is correct.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner. 1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components. My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703 |
12-08-2013, 06:02 PM | #4 |
No ! Gm makes a few different seat belt bolts , The one you have is for the center floor pan location it is a 13/16 bolt they make another that has a shorter shoulder for the pillar post location ...so it still swivels but doesn't flop around sloppily ...
12-08-2013, 11:32 PM | #5 |
That's kinda what I was thinking since it doesn't just swivel, it flops sloppily. I currently have a single lap buckle belt - I assume that the bolt pictured would be more appropriate for mounting two lap buckle belts together, and the bolt that's currently securing my single lap buckle belt would work for the shoulder belt.... Does anyone have the specific lengths of the shoulder portion of the bolts for those two anchor points?
12-09-2013, 08:57 AM | #6 |
There are 3 sizes for these trucks
One has no shoulder and is used for the outside closest to the door The second has a short shoulder and is used at the shoulder belt anchor point The third has the longer shoulder and as you said is used in the center floor position for anchoring 2 sets of belts to 1 anchor point used for the extra 3rd passenger in the center seat , hope that helps |
12-09-2013, 10:25 AM | #7 | |
No factory shoulder belt bolt. Only had lap belts in 67. |
12-09-2013, 10:40 AM | #8 |
Do a search on EBay. I have seen two size lengths maybe what you need. I believe only $2 a piece.
'69 Chevy Long Fleet & '71 GMC Short Step & Project "ODD BALL" "You can wash a pig, soak it in most expensive perfume. In the end it is still just a pig." ODD BALL build thread http://67-72chevytrucks.com/vboard/s...d.php?t=478629" |
12-09-2013, 11:35 AM | #9 |
Roadtrip!
Shoulder belts were available in 67. There is actually a set for sale in the parts section.
67 gmc custom lwb dakota truck. Sold...And bought back 69 swb 4x4 project (in progress) 70 c-10 lwb texas truck 70 4x4/BB/bkts/posi/tach(retired) 70 swb (wifes) 70 jimmy camper 71 K-5 factory 2wd 71 cheyenne 4x4/tach/posi/ plow rig 71 Cheyenne20 BB, buckets, tach, tilt, 4 speed 72 jimmy CST wyoming rig 72 jimmy Colorado rig 72 lifted texas 4x4 3/4 ton burb 65 fury conv. 383/auto 65 chrysler 300 "L" 413 auto |
12-09-2013, 11:58 AM | #10 |
I think this is what will fit it says shoulder 72 C-10
http://www.ebay.com/itm/GM-SEAT-BELT...1ad972&vxp=mtr
12-11-2013, 01:48 PM | #11 |
No , it has to have a shoulder to allow the belt to swivel . the ebay picture you posted are for late model seats /truck
12-11-2013, 01:55 PM | #12 |
How about this:
http://67-72chevytrucks.com/vboard/s...&postcount=518
'70 cab, '71 chassis, 383, TH350, NP205. '71 Malibu convertible '72 Malibu hard top Center City, MN |
12-11-2013, 01:57 PM | #13 |
12-11-2013, 02:01 PM | #14 |
Moderator
Here is how mine are mounted. These are the bolts that were original to the shoulder belts.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man |
12-11-2013, 02:19 PM | #15 |
Roadtrip!
Look up member 71 super
Looks like he sold them on 12-6 (don't know how to post a link)
12-11-2013, 02:42 PM | #16 |
Found them. But that doesn't prove there where some in 67.
http://67-72chevytrucks.com/vboard/s...d.php?t=606828 |
12-11-2013, 03:13 PM | #17 |
Moderator
Those belts Harold had are 67, you can tell by the male buckle ends...I also have the same style. It is well documented that shoulder belts were an option in 67.
12-11-2013, 05:36 PM | #18 | |
Roadtrip!
To help this thread out, maybe harold or the new owner could post a close up of the bolts pictured.
12-11-2013, 08:29 PM | #19 |
Here are pictures of belts, there are 1967 belts....
67 blue step side- bb 68 gold and white swb cst anniversary 68 custom swb hot rod Ls swap 69 swb cst 6 cylinder/ overdrive 69 black/black cst bb swb 70 orange and white cst Canada built truck swb bb 71 black and white super swb bb 71 red and white super swb 72 green and white super swb 4x4 62 nova wagon 400 series Ls swapped 68 Camaro 327/4 speed- 1 owner, original paint 66 Volkswagen bettle 69 auto stick Volkswagen Beetle |
12-11-2013, 08:30 PM | #20 |
More
12-11-2013, 08:30 PM | #21 |
And more
12-11-2013, 08:31 PM | #22 |
Shoulder belt bolt
12-12-2013, 11:09 AM | #23 |
Curious since I never seen 67 shoulder belts before. Are the buckle ends aircraft style with the bow tie raised lifting release type the same as the lap belts?
12-12-2013, 11:18 AM | #24 |
yes they are. the Chevy trucks in 67 only had the raised bowtie on the buckle gmc trucks had the same latch just smooth with no raised bowie. the 67 and possibly earlier truck shoulder and seatbelts also use a different mounting plate to the floor than 68-74. the one that mounts to the pillar is the same throughout all the years.
12-12-2013, 11:23 AM | #25 |
Then it is possible some maybe found in a Camaro or Chevelle as I have seen the same lap style in those also.
