Front disk brake shield
How did gm have the bolts and what torqe were they on the front disk brake shield
Re: Front disk brake shield
Torque? Just tighten, they don't support any thing other then their own weight which is next to nothing.
1957 CHEVY 1/2 TON SHORT BED 1940 FORD 1/2 TON SHORT BED |
Old member
I'm sure GM had a spec for them but as stated they aren't holding anything other than themselves so I would tighten them good and snug.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
Watch out for your cornhole !
![]() Join Date: Jun 2003
They're 5/16 bolts if you want to reference a torque chart.
