Old 12-08-2013, 10:17 PM   #1
mechanic350
mechanic350's Avatar
Project: Long Time Coming
Ive decided to start a build thread since ive already started one thread on here about my 72. and i decided to title it long time coming. ive wanted a 72 for about 15 years now and i finally was able to find one and i could afford it. ive definitely got some big plans for her. i attached the link so there are a few pics to go along with this.
http://67-72chevytrucks.com/vboard/s...d.php?t=607070
1972 Chevrolet swb fleet side. - SOLD
2018 Toyota Tacoma but hunting for another C10
Link to my build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=607303
Instagram: https://www.instagram.com/72c10shortbox/?hl=en
mechanic350 is offline   Reply With Quote
Old 12-28-2013, 12:18 AM   #2
mechanic350
Re: Project: Long Time Coming
Was finally able to get the Bed Rhino lined. Took a few days to do it but it turned out ok.
Old 02-22-2014, 12:30 PM   #3
mechanic350
Just got the last of the parts I was waiting for to put in wilwood 13" big brake upgrade for the front and rear on the truck. And a buddy is gonna hook me up with a 9" chrome brake booster he has and a freshly rebuilt holley 750cfm 4 barrel carb.
Old 02-22-2014, 04:52 PM   #4
sduckworth13
sduckworth13's Avatar
Didn't look like you had any rust to deal with, that always speeds things up. Bed floor looks nice.
Scott
sduckworth13 is offline   Reply With Quote
Old 02-22-2014, 07:21 PM   #5
mechanic350
Yeah i got lucky with the rust. only a few spots with some surface issues. other than that its was more just getting the old paint off and the bedliner on.
Old 05-21-2014, 02:10 PM   #6
mechanic350
so i was finally able to find some time to install my new brakes on the truck. sadly she is still on jack stands because i haven't been able to get the parking brake adjusted so that it will engage and allow the truck to not roll away on me. unfortunately i broke my hand so getting her back on the ground will have to wait a few more weeks. here are a few pictures of the old equipment and the new equipment.
Old 05-21-2014, 02:12 PM   #7
mechanic350
Sorry I have to upload these one picture at a time from my iPad because my computer won't let me upload pictures. Here's the truck on jackstands
Old 05-21-2014, 02:13 PM   #8
mechanic350
Old brake rotor and spindle
Old 05-21-2014, 02:15 PM   #9
mechanic350
New hub and spindle with caliper bracket
Old 05-21-2014, 02:16 PM   #10
mechanic350
New front rotor installed
Old 05-21-2014, 02:18 PM   #11
mechanic350
Picture of the new caliper from the end
Old 05-21-2014, 02:18 PM   #12
mechanic350
Phew rear brake fully installed
Old 05-21-2014, 02:37 PM   #13
mechanic350
So a few things to note on this. I used the wilwood 13" big brake kit specifically the super lite 6 in front and super lite 4 with internal parking brake for the rear. Part number140-10775-D for the front and 140-10093-D for the rear. Word of caution though on the kits. The front is designed to be used with CPP drop spindles. Sadly I didn't have these so I had to purchase them and then wait to continue my install later. Also the internal drum (parking brake) feature of the rear brakes is designed to be used with the wilwood extended brake cable kit. Part number 330-9371. I also purchased wilwood disc brake fluid and a new adjustable proportioning valve to replace the old one I had before. Over all a very easy kit to install. I did need to pull the rear axles in order to I install the rear brakes. Pretty easy to do. Just make sure you buy new diff fluid and a new gasket when you do. I was able to bleed the brakes with the help of my wife even though she was 8 months pregnant at the time. And the all work pretty well now. I haven't been able to break in the new brakes yet since the parking brake still isn't working fully. Hopefully I'll be able to do that soon once I get this broken hand out of a cast. Anyone who wants more info just ask. And I want to say thank you to the guys at CPP, AZ pro performance, and wilwood for their technical help.
Old 05-21-2014, 03:38 PM   #14
mechanic350
thought i might add a picture of her as she sits now
Old 06-09-2014, 11:47 PM   #15
mechanic350
After a long break due to a broken hand and my wife giving birth to our first child, I'm actually going to be able to try and do some work on my truck tomorrow. Hopefully I can make some progress on the brakes and maybe get her back on the ground soon.
Old 06-23-2014, 12:20 AM   #16
Low68
Low68's Avatar
Nice. You driven the truck since you put the brakes on there?
Build Thread
Low68 is offline   Reply With Quote
Old 06-23-2014, 12:29 AM   #17
mechanic350
Sadly no. I've been having a terrible time getting the parking brake setup. Saw that you were running a similar setup with the brakes. How did you run the parking brake cable on yours? Great build btw. I'm looking at doing a lot of the same to mine.
Old 06-24-2014, 09:07 PM   #18
mechanic350
Put my truck back on the ground today. pretty good feeling. hopefully tomoro i can get the timing set so i can start breaking the brakes in and driving her every day again.
Old 07-15-2014, 09:17 PM   #19
mechanic350
so i finally got the old girl running and the brakes broken in and its great to be driving her again. i also found out that the trans is actually a TH350 and not a 700r4 so that was a major buzz kill. another thing on the list that keeps growing of things the previous owner neglected to mention or just lied about. and the reason i didn't know was i didn't know how to tell the difference and didn't think that it was anything but what they said it was.
Old 09-24-2014, 01:11 PM   #20
mechanicalman
Those are some nasty looking breaks. Did you get re-casted after 6 weeks? I'm thinking you might have needed surgery and external fixation or something inside to keep that lined up straight.
mechanicalman is offline   Reply With Quote
Old 10-14-2014, 12:29 AM   #21
mechanic350
yeah i ended up getting 5 pins put in my hand and some surgery to fix the damage.
Old 10-14-2014, 12:30 AM   #22
mechanic350
so after a long break i was able to swap out the ignition system and get the old girl back on the road so i think ill be taking her to the cruisin grand on friday if anybody else is gonna be there.
Old 10-20-2014, 10:25 AM   #23
vegadesign
vegadesign's Avatar
Clean looking truck. I know how it is to try and wrench with broken bones, no bueno!
I'm trying to get a big c10 get together here in San diego. So If you are interested and know people that would. Hit me up so we can make this happen sooner
"its not a hobby, It's a Lifestyle"
bagged and soon to be bodied 70 longbed
http://67-72chevytrucks.com/vboard/s...d.php?t=564028
vegadesign is offline   Reply With Quote
Old 10-20-2014, 04:25 PM   #24
mcbassin
Still Learning
mcbassin's Avatar
Very nice truck you have. Digging the brake upgrades! the broken bones....not so much.
mcbassin is offline   Reply With Quote
Old 10-21-2014, 08:38 PM   #25
mechanic350
Thanks for the compliments on the truck. Vega design I'm totally down to do that. I have a neighbor with a 72 long bed that might join too. And I know there are plenty of guys local that would be up for it. Yeah mcbassin the brakes were pricy but very worth it. And wrenching with broken bones sucked.
