Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > Heavy Haulers
Old 12-09-2013, 11:14 AM   #1
firels1
brake chamber
1974 gmc 6500 w/F090 front axle. Any idea what brake chamber fits this truck? I think its a type 16 but I am not sure. Any info would be great. Thanks
firels1 is offline   Reply With Quote
Old 12-09-2013, 12:53 PM   #2
marvgarr68
marvgarr68's Avatar
Re: brake chamber
Should be a type 16 remove the diaghram and look in the center will have a
stamp with the size.
1976 k20, 350 built, 44/14 axles
1968 c10 6.5 turbo diesel,t5 trans
1977 gmc c3500 dually, crew, 4-53t, 5&3 trans
http://67-72chevytrucks.com/vboard/s...d.php?t=591188
marvgarr68 is offline   Reply With Quote
Old 12-09-2013, 01:43 PM   #3
firels1
Re: brake chamber
There are no markings on it. Only diaphram says 16. Do you have a part#-brand that is a direct fit? There are a lot of different type 16 brake chambers.
Old 12-10-2013, 02:11 AM   #4
marvgarr68
marvgarr68's Avatar
Re: brake chamber
Thats the stamp its a type 16. What is wrong with the old one leaking? If its just leaking just replace the diaghram you can get it at napa. Tell them you need a single pod type 16 brake chamber diaghram make sure its standard stroke.
Old 12-10-2013, 02:14 AM   #5
marvgarr68
marvgarr68's Avatar
Re: brake chamber
Here it is you sometimes have to cut the rod to the same length as the old one.
http://www.napaonline.com/Catalog/Re...e-25000/Nao-10
Heres just the diaphragm
http://www.napaonline.com/Catalog/Ca...P16_0213507155
Old 12-10-2013, 08:32 AM   #6
firels1
Re: brake chamber
Thank you. One of the chambers broke a spring, other wise I would of just replaced diaphram.
