Old 12-09-2013, 12:24 PM   #1
walkerb
walkerb's Avatar
A833 MOPAR to chevy question
Instead of asking in Keith's Intro thread I thought I would start this thread.
My plan is to swap this into my 250 6cyl 1974 stepper that currently has the Saginaw 3spd.
I've read a bunch of the archives( maybe not enough) and still have a couple of questions
1. A833 MOPAR will fit using Chevy bell housing correct?
2. Will my Saginaw bell housing work? Or does it need to be the 80-87 A833 bell?
I ask because I can get a Mopar a833 locally. Thanks for the help!
1973 k20 Suburban 350
1974 Custom stepside c-10 250
1975 Chevy stepside 454
1986 K30 Crewcab SRW 350
R.I.P- glimmertwin01- board member and good friend, you will be missed
walkerb is offline   Reply With Quote
Old 12-09-2013, 01:21 PM   #2
Keith Seymore
Keith Seymore's Avatar
Re: A833 MOPAR to chevy question
I don't know a lot about the conversion, since my truck came that way.
However, in reading the attached link...
http://www.customclassictrucks.com/t..._transmission/
...I have a couple observations:
1) Sounds like you have to have either a MOPAR case or a GM case to fit the desired bellhousing.
From the article: "Chevy offered this as a COPO option on 1/2-ton trucks from '81-87, known as MY-6. There are two versions of the Chevy case: the first has the regular GM mounting ears to the bellhousing, while the second retains the Chrysler mounting pattern and requires the specific factory aluminum bellhousing. We have one with a boss for a hydraulic clutch slave, and we've seen a picture of one with a Z-bar ball stud on the side. It looks to us like Chevrolet simply modified an existing mold for the bellhousing-silver plastic push-in plugs fill the unused Chevy mounting holes. "
2) I just noticed an error in the article. They referred to the trans as a "COPO" (Central Office Production Option), which is not correct. It was a regular ole' production option (RPO MY6), just like the Saginaw (M62 or M64).
K
Chevrolet Flint Assembly
1979-1986
1986 - 2019
Old 12-09-2013, 05:00 PM   #3
INSIDIOUS '86
INSIDIOUS '86's Avatar
So what about fitting a NON overdrive a833 in behind a Chevy. These boxes are probably one of the stoutest 4spds ever made and were fine behind wheel standing hemisphere back in the day.
All my searches lead to the overdrive version and nothing for the regular 4spd.
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac
3''spintech prostreet mufflers xpipe 1 3/4 headers
build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217
Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511
INSIDIOUS '86 is offline   Reply With Quote
Old 12-09-2013, 08:43 PM   #4
TheBlueBomber
TheBlueBomber's Avatar
Is the A833 like the SM465 or completely different? Curious cause this is the first time I've heard of it.
Austin
1996 Chevrolet K1500 Silverado
1979 Chevrolet K10 Scottsdale - Carolina K10 -
My 4.8L Twin turbo build - Project Short Stroke -
Instagram - TheBlueBomber1996
TheBlueBomber is offline   Reply With Quote
Old 12-09-2013, 09:53 PM   #5
INSIDIOUS '86
It's way different. The sm465 is a dump truck transmission. Bigger heavier and hard to shift.
Look up the a833. Lots of info online.
Old 12-10-2013, 02:17 AM   #6
Rubble
I got the 833 behind a 6.2 in my 82.Nice combo,really nice shifting trans.Lot shorter throws than my 465 trucks too!!
1977 Chev C30 454/465/14ff DRW
1974 Chev C20.350/465/14ff
" Rock n Roll ain't noise pollution"
Rubble is offline   Reply With Quote
Old 12-10-2013, 06:35 AM   #7
D13
D13's Avatar
Input shafts are different Chevy to Mopar, as are output shafts.
It may take some searching but there is a pretty decent thread on here about these. Somewhere. A couple of years ago.
1987 2 ton
1982 250/TH350 beater in progress
Dad's 1981 3/4 L6 3 on tree posi and no options, awaiting restoration or scrapping
Plus a mess o' tractors
D13 is offline   Reply With Quote
Old 12-10-2013, 08:06 AM   #8
Keith Seymore
This is a good link:
K
1979-1986
1986 - 2019
Old 12-10-2013, 04:40 PM   #9
TheBlueBomber
Thanks for the link Keith. I guess I know what ill have my eyes peeled for now.
Austin
